5.4/4.6 oil consumption? - Ford Truck Enthusiasts Forums
Old 06-13-2003, 05:10 PM
The Huns The Huns is offline
The Huns is starting off with a positive reputation.
How many of you guys/gals are having this problem? Im just curious because Im considering a new f150 as my next truck,but I've read some people posting about this and even thinking its "ok" for a truck to consume oil between 3000 mile intervals.Im a Toyota driver that would love to go back to a American truck,so Im hoping this isn't typical of these engines.
P.S.I know Im not going to see many "Yee Haw my truck doesn't use any oil" post,so thats why Im trying to get real world feedback from satisfied customers.
Thanks
Randy
Old 06-13-2003, 10:10 PM
fknipfer1 fknipfer1 is offline
fknipfer1 is starting off with a positive reputation.
Had two 5.4L and neither ever used any oil between 3000 mile changes.
Hope this helps.
Old 06-14-2003, 03:56 AM
DavoXT DavoXT is offline
DavoXT is starting off with a positive reputation.
Have a new ford falcon with the 3V head 5.4lit triton V8 and live in the outback of Australia where the tempiture can reach 110deg.
She hasn't used a drop of oil between services.
Davo
Old 06-21-2003, 09:41 PM
1ruralmailman 1ruralmailman is offline
1ruralmailman is starting off with a positive reputation.
i drive a 99 250sd with 5.4 engine,does'nt use any oil between changes. id be interested to know how many with use problems are using motrcraft filters,i have never been able to get any other brand to totally seal on the block.
Old 06-22-2003, 01:27 AM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
Mine hasn't used a drop either!!! I always use Motorcraft filters.
Old 06-22-2003, 04:06 AM
Thanks for the feedback,guys.I just saw a couple of post where people said they had 4.6 's using oil. I just wanted to make sure it was just a few isolated cases.
Old 06-22-2003, 11:46 AM
03f150man 03f150man is offline
03f150man is starting off with a positive reputation.
1997 4.6 windsor with automatic. Zero oil consumption between 3,000 mile oil changes. Truck has over 147,000 miles on it.
Old 06-22-2003, 07:30 PM
chad E250 chad E250 is offline
chad E250 is starting off with a positive reputation.
I took my van to the dealer because of the oil consumption. The service manager told me that this was normal for this motor (5.4) I cannot find any leaks anywhere and the exhaust does not have any signs of oil burning. I have a hard time accepting a new engine burning almost a quart of oil in 3k miles.
Old 06-27-2003, 02:31 PM
Black1 Black1 is offline
Black1 is gaining momentum as a positive member of FTE.
I'm new here (first post).
I have 111K on my 99 5.4 and it uses a quart every 1K. It has from the beginning. I bought the truck new. I was using Fram filters until I just learned some things about them. I'm using motorcraft now. I just made the switch last oil change. The first 1K since the oil change I'm only 1/2 quart low, so that seems to have had some affect.
Regardless, this engine uses more oil than all the other vehicles I've ever owned combined. Aside from the oil consumption issue though, I've been reasonably happy with it.
Old 06-27-2003, 04:38 PM
ggarrahan ggarrahan is offline
ggarrahan is starting off with a positive reputation.
Every piston engine must consume some amount of oil, you have to allow lubrication of the rings on the bore and the valve guides. To control excessive consumption in the bore, they add the lower, usually 3 peice, oil control ring which is designed to "wipe" the excess oil out of the bore on downstroke, and they have the rubber (viton) valve guide seals. The question is what is excessive. I don't think a quart every 3000 miles is excessive, nor is it something to worry about. Even a quart in 1000 miles may be ok on a higher mileage motor, as long as the plugs are not getting fouled, and the engine is otherwise performing properly. I had a Ranger that used a bit less than a quart in 3000 miles, but ran fine. I look at it this way, oil is cheap, throw a quart in if it needs it and drive!
Old 06-27-2003, 07:09 PM
GR8Diesel GR8Diesel is offline
GR8Diesel is starting off with a positive reputation.
I think that if you have to 'add' between oil changes there is something amiss... Either you aren't changing oil properly. the engine is being exposed to unusual service, or the consumption is 'excessive'. It is true that some oil is lost, but it should be very little. I have had two 5.4L engines in my 99 Expedtion. First engine didn't loose enough oil to drip, but it did stink from the bad head gaskets. At 20K, new head gaskets were installed and no more oil consumption. At 30K, the engine was replaced due to piston knock (wrong size bore) and the replacement engine's oil level doesn't change over 3k miles. Although I wasn't thrilled at having these problems, I have to say 'kudos' to Ford for standing behind their products.
Old 06-30-2003, 10:59 PM
sportscar's Avatar
sportscar sportscar is offline
sportscar is starting off with a positive reputation.
If I do any WOT driving, my 2001 will suck down a qt fast. From what I can tell from this board and discussions with the guys at my dealer, the 5.4 is prone to oil comsumtion. Mine can use a qt in 1000 - 2000 miles. The dealer tells me Ford considers 1qt/1000 "normal" for the 5.4
Old 07-01-2003, 11:10 AM
2000Expy's Avatar
2000Expy 2000Expy is offline
2000Expy is gaining momentum as a positive member of FTE.
Red face 5.4/4.6 oil consumption?
I had an 86 Toyota truck until about 2-3 years ago. It always used a little oil, and I bought it new.
Old 07-01-2003, 04:22 PM
D Harry D Harry is offline
D Harry is new and has a neutral reputation at this point.
OK, I'm getting my .02 cents in on this one. 95 T-Bird with the 4.6L V8. It burns a qt. every 2,000 miles from the day I bought it brand new! Not really used to this kind of oil consumption from new cars. Immediately went to 10-40w instead of the 5-30w or 10-30w ford recomends. Helped a little. At 60,000 miles I switched to 20-50w... helped a little. Still goes through oil.
At 115,000 still goes through oil.... but nothing has every gone wrong with the motor. Just gotta watch it so ya don't run out of oil. Only thing that has gone out was the tranny at 66,000 and the MAF on the air intake at 95,000. I'm in So. California.
Good Day All,
Harry
Old 07-01-2003, 09:57 PM
ggarrahan, agreed that piston engines must consume some oil due to oil vaporization during internal friction. for reasons unknown to all but Ford motor company, six quarts of fresh oil and an oil filter change leaves the dipstick about half full. There is some lettering on the dipstick and a fresh oil change leaves the oil level at the top side of the letter "O". I change my oil every 3,000 miles and check it regularly and always check the oil just before i refill. The engine oil level after 3,000 miles is on the bottom side of the letter "O" which on my truck is equivalent to about 1 ounce, maximum 2 ounces, of oil. Realistically speaking to me that is equivalent to zero oil consumption because a certain but unknown amount of oil is clinging to the engine insides. and as mentioned in my earlier post, this is on an engine that now has 148,500 miles.
2015 Super Duty trucks - Are dealers making deals? Big-Foot Car/truck Buying Advice 1 06-05-2014 11:13 PM
Changed transmission oil Help!!! Randy777 6.0L Power Stroke Diesel 4 04-19-2014 11:50 PM
Does anyone have an Engine wiring diagram for a 86 bronco w/ a carb 351w? RandyS503 1978 - 1996 Big Bronco 13 04-10-2011 10:19 PM
Oil capacity in 87 F250 4x4 W/460 Cricket460 1987 - 1996 F150 & Larger F-Series Trucks 2 01-27-2003 11:18 PM
Tags
2002, 46, 46l, 54, burning, consumption, engine, f150, ford, lt, oil, premature, quarts, triton, type
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
