Sync / Blue Tooth
Sync / Blue Tooth
Hey all,
Have another question if I may -
My 2008 has a phone button on the radio - when I press it, it says "no phone". It doesn't mute the radio.
I guess I need an adaptor or accessory to make it bluetooth capable? Also can a sync system be installed on an 08' - or not worth it?
Thanks!
Thanks!
I know on My 09 mustang I have the same button. there is a module from Ford that will upgrade it but it is $600 for the module and then the computer in the car has to be reprogrammed by Ford )more money). I was told that there was a change mid 2008 and if you have an earlier 08 one it won't work. not sure if Expeditions are the same.
bluetooth
my 08 required a MobileEase installation to use a Bluetooth phone - had it installed at CarToys when the Expy was new - it was a few hundred bucks to buy and install
small device installed on dash next to the 4wd selector and a mic attached above the rear view mirror
works great but wish it had a display (maybe it does by now)
mcanavan69
09-05-2011 05:28 PM
TheMilkman00
1997-2006 Expedition & Navigator
08-09-2006 03:11 PM
Triboy
06-13-2004 11:34 PM
