Is the factory HD tow package enough?
Been reading conflicting information on if the HD tow is good enough to cool. I have also read that there are many different coolers offered on the 3rd gen expedition anything from a 11, 7, and 5 plate setup. Mine has 8 plates that looks to have 6-7 actual usable plates at ~23" long so it looks like I have the "updated" HD trans cooler.
My wonder is how well the standard system cools the engine and transmission in high heat/humidity that I typically haul in. Should I be concerned? Should I look into aftermarket coolers? or am I good enough with the "updated" HD setup?
No trailer yet, I bought this truck for the long haul and eventually Id like to get a trailer for the family and would like to be able to tow the Jeep(~4500 wet + gear + trailer) here and there. Not to mention I may have to tow my buddies party barge. So no specifics yet, just need to know how well the HD cooling handles real world towing as it gets hot and humid where I frequent.
Johnny
It would be interesting to note the sensor location. I occasionally pull a 20ft boat over mountain passes and steep hills in the Pacific Northwest. I have occasionally broken 200 deg F but it usually is 185-195 in 100 deg ambient temps. While not towing it stays about 175-185 deg F.
I have considered this normal but I have noticed that this year the temps are a couple of deg warmer on average than they were last year. I only have 15K mi on my '11 Limited. Last year I was about 10K mi.
Johnny
You're right, I use a Scanguage II. It is worth it's weight in gold IMO.
Johnny
Johnny
Im seriously considering an aeroforce gauge for the truck as it will be alot easier then having to get a block installed and having to run wire from inside to under the truck. Plus it reads 2 PIDs at a time and can switch between so many and it scans and clears DTCs making it a no brainer.
Thats how my jeep was in the summer time. I hit 214 in it once hauling ~1800lbs in the cab/roof/hitch on the way to lake gaston. But that was pan and I surely damaged my transmission that day or at least wore it out a decent bit.
The scan gauge reads 4 sensors at a time. I usually leave it on AVG MILEAGE<instant mileage="">, INSTANT MILEAGE<average mileage="">, TRANS TEMP <engine coolant=""> and ENGINE TEMP<trans temp="">. It is plug and play. Except you do need to program the correct Transmission Temp. It will also provide you with current trip computer info (Mileage, Max Speed, Max Tach, Miles Driven, Hours Driven, Avg Mileage and a few more) Today's info, and yesterday's info as well as Tank Info. Mileage is much more accurate than that of the built in mileage in the instrument panel. </trans></engine></average></instant>
Also the temperature gauge in instrument cluster runs through the computer, therefore it doesn't show changes in temp like the Scangauge, it just sits pretty in the same spot even if the temp get's pretty high. I guess the engineers don't want you to know anything.
I have no affiliation with Scangauge just a happy customer.
What year is your Expedition?
Johnny
Last edited by Johnny Law; 08-15-2013 at 09:24 PM. Reason: I used GT LT symbols in my text and it removed the text inside
