Zf5 swap clutch line issue with snapping in - Ford Truck Enthusiasts Forums
Old 08-05-2013, 08:37 AM
88gtblack 88gtblack is offline
88gtblack is starting off with a positive reputation.
Completed the ZF swap. I used the quick disco tool when disconnecting the clutch line on the Mazda tranny
When putting the clutch line on the zf5 it wont snap in!
Opened the bleeder valve and tried-no luck. The white plastic grommet is new. And I removed the old one from the zf5 and they look the same.
My truck is a 96 4.9 m50d 2 wheel drive. 8 foot bed reg cab
the ZF5 is a S42 manufactured in i believe mid-late 92.
What gives????
Old 08-05-2013, 10:05 AM
EDIT: WRONG SLAVE CYLINDER FORD CHANGED SLAVES IN 93 MY TRANS IS A 92 SLAVE IS WRONG CLUTCH LINE WONT WORK TRANS HAS TO COME BACK OUT FAIL
Zf5 to zf6 swap XBAJBUSX 1994.5 - 1997 7.3L Power Stroke Diesel 23 10-22-2014 07:43 PM
Zf5 swap help clutch/flywheel Feardeere7 1973 - 1979 F-100 & Larger F-Series Trucks 0 10-06-2014 10:10 AM
c-6 to zf5 trans swap? TrainPRes 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 01-13-2014 08:36 PM
Swap M5OD Mazda to ZF 5 speed in a f150 is it a direct bolt up Jason302 1987 - 1996 F150 & Larger F-Series Trucks 32 01-12-2014 12:24 PM
F250 Mazda 5speed to ZF-5 Swap? FarmTruck1 1987 - 1996 F150 & Larger F-Series Trucks 6 06-24-2011 11:12 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
