Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all:
- Why is my Truck Vibrating?
Guide to diagnose trouble and recommended solutions
Browse all:
That strange 60 to 65 MPH vibration towing my boat
I have a 2103 F150(5500 miles) and a 2013 Ranger Z522 bass boat( 23'-4800 lbs 3000 miles). I get that ole strange vibration between 60 and 65 when towing) My tire dealer balanced all 8 wheels for me. I tried to get my truck to do it by itself but did not notice. It does not do it all the time. I'm going to say about 1/2 the time it does it and then it will not. It only does it at that speed range which to me at one time was a wheel balance problem. When it does it i can see the head of my trolling motor on my boat vibrate with it. I did try to give the truck a little power to see if it effects it. It did not. I did this because back in the 80's i had a truck that the drive shaft was a little out of balance. Power to the drive chain would effect it enough that you could notice. I've tried to get the truck to do it by itself but can't. Anyone got any secrets that might help me.
The only thing that I have read to help that is changing the pinion angle of your driveshaft. The other thing that will help is installing the RAS which will not allow the truck to sag enough to change your pinion angle when you have the boat loaded. One guy on another site added a leaf to his rear springs that also took care of the problem for him (axle wrap).
I am in the same "boat" as you and will either be adding another leaf to my springs or the RAS system.
I want to look into this and check out some options to assist. Shoot me a PM with your information and I'll get to work; be sure to include your VIN, dealer, mileage, daytime phone number, and full name.
Crystal
Heheheeee, old ARK didn't get the PM part. It's okay, ARK, you are safe with me! Anyway, oh me, I'm so wanting a new truck. It seems now that F150's main problem is this shuddering at various speeds - I can stand a heap o' things, but not nary vibrating, shuddering and otherwise non smooth riding truck.
little more advise
ARK, from all me forum reading, I'm saying its between ye transmission and differential. Now, I know that's a heap of a long way, but it seems most of these shuddering, vibrating problems are somewhere in the drive shaft area, not wheels. Now, he, I could be wrong, but it would be rare...
bed 3.55 e locker rears with 7700 gvw package.
