Clearence lights HELPPPP!!!
Old 08-05-2013, 07:12 AM
sitInHigh's Avatar
sitInHigh
sitInHigh is offline
Hey Guys I have a 1999 F250 SD I just ordered some clearance lights from RECON I had a question if the wiring part is default thats all im kinda worried about, I mean drilling in to my roof is scary but im gonna measure 1000 times.
Old 10-26-2013, 10:54 AM
srteach's Avatar
srteach
srteach is offline
What do you mean by default?
There is a + side and a - side to each circuit. With general lighting (where you want to hook these lights), the switch is on the + side and - goes to ground. If you are using LED lights, make sure you don't get the + and - mixed up, LEDs will not work when switched around.
With interior cabin lighting, the + is constant and the ground has multiple switches.
Old 10-27-2013, 05:37 AM
tjc transport's Avatar
tjc transport
tjc transport is offline
i ain't rite
Received 3,081 Likes on 2,151 Posts
if you do not have roof lights, you will most likely have to add the wiring harness that goes down to the connector behind the passinger side kick panel
HRTKD
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
04-24-2017 07:29 AM
crestfallinman
05-17-2008 11:22 PM
79driver
1999 to 2016 Super Duty
08-24-2006 10:21 PM
GR8 1
09-10-2003 12:49 AM
Quick Reply: Clearence lights HELPPPP!!!
