tranny issue? Hard shift from 4th to 5th? - Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8
Old 08-05-2013, 07:37 AM
goingnorth goingnorth is offline
goingnorth is starting off with a positive reputation.
I am 500 miles from home and my truck is slamming from 4th to 5th gear sometimes. I havea 5star 87 tune, it did not do it while towing, i will probably put back to stock, anyone have issue like this?
Old 08-10-2013, 09:20 AM
Thenewboss's Avatar
Thenewboss Thenewboss is offline
Thenewboss has a good reputation on FTE.Thenewboss has a good reputation on FTE.
Mine has been doing this for 3 years,but from5 down to fourth. I also have a serious flare from 2nd-3rd. I still have to bring it in to have the TSB done. Last thing I would do 500 miles away from home is mess with the trucks computer, put it in manual and you’ll make it home fine.
Old 08-12-2013, 08:01 AM
I returned it to stock and it is fine, towed it home with no issues, this is not a daily driver so it will be slow to test it out again. I am not sure if I will put the program back in?
Old 08-12-2013, 11:01 AM
2000silverbullet's Avatar
2000silverbullet 2000silverbullet is offline
2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold
What did 5 Star say about it?
Old 08-12-2013, 11:28 AM
Quote:
Put it back to stock and see what happens.
Mike said that the tranny learns and that after towing and running empty it will shift hard in all gears till it learns there is no load attached maybee with in a 100 miles, but I put 150 miles on it after I unhitched before it started slamming into 5th from 4th, but it only did it once and a while, normal drivivng, it also seamed to shift hard from 2nd to 1st, but with 4.30 gears it might be normal, it did that all the time with the tune and less stock.
I only put about 20 miles on it after I put it back to stock before hitching up the TT and bringing it home, it did not act up stock yet. It might be a week before I drive it again.
I did not want to experiment far from home.
On a side note I got the exact same milage with the tune and without towing, 7.6mpg's 8000# TT
Old 08-12-2013, 01:34 PM
fordmdb's Avatar
fordmdb fordmdb is offline
PREMIUM SPONSOR
fordmdb has a great reputation on FTE.fordmdb has a great reputation on FTE.fordmdb has a great reputation on FTE.fordmdb has a great reputation on FTE.
Give me a call or email if we need to adjust we can..
__________________
Custom Tuning for F-E-Series Engines 6.8L V10 / 5.4L V8 / 4.6L V8 / 6.2L V8 / 5.0L V8 / 3.7L V6 / 3.5L V6 / 3.5L EB / 2.7L EBand more!
SCT Custom Tuning Dealer
www.5startuning.com email me here:sales@5startuning.com 843-536-1244
https://www.facebook.com/pages/5-Sta...92086367552400
Old 08-12-2013, 01:48 PM
Quote:
I plan to put some miles on it stock to see if it acts up again, if not I will give you another call.
Thanks.
Old 08-15-2013, 10:22 PM
fordmdb's Avatar
PREMIUM SPONSOR
Quote:
Thanks.
Sounds good. Let me know if you have any questions.
__________________
Old 08-19-2013, 08:25 AM
I put about 240 miles on truck (2 trips to work) after towing with the stock tune and no shifting issues. I called Mike at 5 star and he sent a revised tune with softer shift points, I really could't tell if he just changed 4th to 5th or all shift points? It did seam firmer than stock. I put 120 miles on it and it shifted fine, its 90% highway so not allot of shifting, willl be towing in a couple weekends so well se what happens.
Old 10-08-2013, 05:51 PM
Stanggt24 Stanggt24 is offline
Stanggt24 is gaining momentum as a positive member of FTE.Stanggt24 is gaining momentum as a positive member of FTE.
I have a 13 f-250 SD with Fx4 lariat loaded and mine makes a noise shifting from 2 to 1st started around 8,000 miles and have been fighting with ford since about it. I currently have 22,000 miles and we have reset the computer and it still does it. Not very happy after spending 54,000 plus dollars on special order truck to have tranny issues this soon. Has anyone had same issues and were they able to fix I'm ready to pull my hair out. Thanks Rich
Old 10-09-2013, 07:11 AM
Since my program change I only drove my truck a couple times maybe 400 miles, and it has not done the same thing again from 4th to 5th. Time will tell.
I do notice mine will downshift a little hard from 2nd to 1st with my 4.30 gears. I wonder if the trucks shift at the same rpm regardless of the gearing? That could explain some of the hard shifting issues. I do get a clunk when going in and out of park, my idle seams to high I thought about trying to lower the idle but I think its drive by wire so its not a simple as adjusting a stop screw.
Old 10-09-2013, 06:26 PM
I have the 3.73 gears the dealer drove the same exact truck that I own but different color and they said it made the same noise I'm confused. I don't think a brand new truck should clunk when it downshifts !!!!
M5od issues umgoblue86 Ranger & B-Series 1 07-08-2015 05:30 PM
2013 Navigator towing and shifting GSDSROK 2007 - 2014 Expedition & Navigator 2 08-12-2014 11:36 PM
Transmission problems ciscofreak 6.7L Power Stroke Diesel 1 07-22-2014 05:05 PM
5th wheel/gooseneck Vinford Fifth Wheel & Gooseneck RV Towing 22 02-17-2014 12:19 AM
5TH WHEEL TRAVEL TRAILER FOR SHORT BED??? 2piecespecial 6.7L Power Stroke Diesel 35 08-15-2013 10:21 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
