Performance Parts - Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8
Performance Parts
Old 08-05-2013, 02:46 AM
IKEA52 IKEA52 is offline
IKEA52 is starting off with a positive reputation.
Question Performance Parts
Good Day All,
I have just picked up a 2013 Ford F350 with the 6.2L V8 engine and I am looking to add a few things to it. To start off I have been looking all over the internet for CAI (which I have only found two, K&N and AEF), Exhaust system and a tuner (Which I have been looking at 5Star).
If anyone could provided me with information as to were I could find these types of part it would be greatly appreciated.
Thanks,
IKEA
Old 08-05-2013, 04:21 AM
bikerman2299 bikerman2299 is offline
bikerman2299 is starting off with a positive reputation.
I have an AFE stage 2 intake on my '11 F-250. I really like it. Honestly, it made the biggest difference between all of the parts I've added. I got the dry filter setup since the MAF sensor sits right behind the air filter. At cruising speed it adds a little bit of a rumble, and when I put my foot in it, it adds a very nice growl. I wish you luck on your search.
Old 08-06-2013, 07:22 PM
acf6's Avatar
acf6 acf6 is offline
acf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputation
Go with the AFE over K&N for sure
Exhaust is really your choice, go on youtube and type in 6.2 ford and whatever exhaust brand you want
Tuner go with an SCT device from Mike @ 5 star 5 Star Tuning | Custom Dynomemeter Chassis Tuning Products and Services
Old 08-13-2013, 08:38 AM
unyalli's Avatar
unyalli unyalli is offline
unyalli is starting off with a positive reputation.
Quote:
Is your air box sealed or open?
The Volant CAI on my 05 F150 5.4L was completely sealed and the air boxes intake ports were sealed against openings in the fender well and radiator bulk head. I was very happy with this system as there was no change in sound levels or tone. Like your AFE it was the biggest noticable change in performance on the truck. Volant is not interested in the 2011+ 6.2L SD's so I'm looking around.
Jeff
Old 08-13-2013, 09:31 AM
The AFE Stage 2 uses an adapter the attaches to the lower airbox, using the stock clips on the lower box. The air filter goes through the new metal upper part of the airbox. It seals against the bottom of the hood. It uses the stock intakes in the lower box and fender. The only thing I didn't like was the overall fitment of it. It was VERY tight! Certain parts didn't line up exactly right. I even sent pictures to AFE, and they were baffled. But, I got everything to fit. I think it was just a manufacturing fubar that day. The part I don't like about the AFE setup is that when you take out all of the old O.E. resonance tubing, there are a few wiring looms that are held by the resonance setup and AFE made no provisions for these wires to be secured to anything. Thus zip ties and a little bit of fabricating. But other than that, I really like the setup. It added a nice kick to the low end. Wish you the best of luck deciding.
Old 04-19-2014, 06:31 PM
Now what ...
Good Day All,
Been doing something thinking lately as to what I can upgrade next for better preformance and better lower end torque. So far I have done the following:
1. Edge CTS tuner.
2. aFe 2 stage cold air intake.
3. aFe throttle body spacer.
4. Gibson exhaust.
5. Changed from 3.73 gear ratio to 4.30 to compensate for 37" tires.
6. EBC brake system.
7. Optima battery.
8. Front and rear trail ready bumpers.
9. PIAA fog and ATP lights in the front bumper. Back up lights in the rear bumper.
I know some of the above upgrades won't improve performance or torque but now I'm thinking what to do next.
If anyone has any ideas or suggestions please feel free.
IKEA
Old 05-01-2014, 04:55 PM
Strokin_power Strokin_power is offline
Strokin_power is starting off with a positive reputation.
if you are changing gears go even further.
Old 05-01-2014, 10:04 PM
Quote:
Good Day Strokin_power,
What are you thinking that I Gould go further too?
Old 05-02-2014, 05:45 PM
GTXgp's Avatar
GTXgp GTXgp is offline
GTXgp is starting off with a positive reputation.
If you are going with an aftermarket intake on the 6.2 you really need to consider a tune to go with it. The stock tune causes an aftermarket intake to resonate quite a bit, it also doesn't know what to do with the extra air and can cause the air/fuel ratio to be out of whack. Getting a tune at the same time will allow the intake to work at its peak efficiency.
Old 05-19-2014, 09:17 PM
tjcprop's Avatar
tjcprop tjcprop is offline
tjcprop has a very good reputation on FTE.tjcprop has a very good reputation on FTE.tjcprop has a very good reputation on FTE.
Quote:
Originally Posted by IKEA52 View Post
Good Day All,
1. Edge CTS tuner.
4. Gibson exhaust.
7. Optima battery.
IKEA
I had the 4.30 gears installed on truck at purchase as I knew 37s were being installed with a 6inch radius arm lift. Instead of the Optima battery, I suggest NorthStar 99.9% lead battery. I run a snow plow, heater at full, mirror heater, radio, basically lots of electrically without headlight fade with this battery. Also for plowing we installed rear bumper lights. I suggest led lights for this application.
Hope this helps
Old 06-08-2014, 09:57 AM
eberlestock's Avatar
eberlestock eberlestock is offline
eberlestock is gaining momentum as a positive member of FTE.eberlestock is gaining momentum as a positive member of FTE.
I bought a Rouch intake right from my ford dealer. The same intake fits both the 6.2 superduty and the ecoboost 150
OT Make your own $15 shrinking disc jimcar-9 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 02-01-2016 08:08 PM
Fass Fuel F17 125 GPH 55psi thomil18 6.7L Power Stroke Diesel 7 11-14-2015 09:15 PM
Now what ... IKEA52 6.2L V8 4 04-22-2014 09:12 AM
Wiring aftermarket fog lights on OEM switch IKEA52 Electrical Systems/Wiring 4 04-02-2014 04:49 PM
Garage Storage Cabinets AndrewHR Garage & Workshop 10 01-19-2007 05:41 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
