6.2L V8 Discuss the 6.2L V8
serviced trans.
Old 06-09-2014, 12:49 AM
Flatbed Ed's Avatar
Flatbed Ed
Flatbed Ed is offline
serviced trans.
Did it myself today. Truck has 140,000 so it is due. Not a hard job but it takes several hours to do it right. Removed the pan and found it to be very clean, almost scarey clean. Hardly any shavings on the magnet. Very little cleaning needed. This means little wear on the trans., even at 140,000 miles! Installed new filter and fluid and put it back together. Test drive and all is well!
Now I gotta do the rear-end.
Old 06-09-2014, 05:21 AM
LCT's Avatar
LCT
LCT is offline
Your 12' truck has 140,000 miles?
How is that possible? Godsake that is some serious truckin!
Old 06-09-2014, 11:01 AM
Flatbed Ed's Avatar
Flatbed Ed
Yeah well I've had the truck about 2 years now I drive about 70,000 miles a year more or less
Old 06-09-2014, 12:58 PM
rvpuller's Avatar
rvpuller
rvpuller is offline
Did you just change the fluid that was in the pan or did you manage to get it out of the cooler and converter.
Denny
Old 06-09-2014, 01:42 PM
Flatbed Ed's Avatar
Flatbed Ed
Denny
No I did a simple drain of the pan course I remove the pan and everything but next time umm I'll probably do it in about another 50,000 miles from now I won't wait so long
Old 06-09-2014, 05:43 PM
pacnorwest's Avatar
pacnorwest
pacnorwest is offline
That's a goodly amount of miles.
Are you hauling or towing with it?
What kind of load, if any, is it working under?
Old 06-09-2014, 07:41 PM
RZAR's Avatar
RZAR
RZAR is offline
Nice to see the trans is holding up well.
Old 06-09-2014, 07:57 PM
Flatbed Ed's Avatar
Flatbed Ed
I'm a hot shot driver, so it is worked hard. I haul oilfield parts, no towing. A typical load for me can be as little as 200 lbs, up to 8500 lbs. My average load is about 3500 lbs.
It's just amazing how clean the trans. was. It must be the Mercon LV fluid. Don't ever use anything else...............cheers!
Old 06-09-2014, 08:46 PM
LCT's Avatar
LCT
LCT is offline
Well this post is a true testament to the durability of the 6.2.
My friend, that is some serious driving!
emspjay
12-10-2014 06:14 AM
Truckie256
03-09-2014 07:41 AM
fordcrzymike
Escape & Escape Hybrid
06-06-2013 11:52 AM
2000F2504X4
02-15-2013 09:04 PM
ovenrat
08-11-2003 06:14 PM
Quick Reply: serviced trans.
