U should know the deal buy now Simon. Clean her right up, get the flexible mirror and find out exactly where. Buy the sounds of it , should be easy to spot. Guzzles site sells the rebuild kit. Might be the un servicable plug.
Yes, I know. I was wondering if there is any seals that are replaceable around there that I could try replacing before I go to the trouble of pulling out the HPOP.
Guzzle should have the answer.
Just the seals on the HPOP hoses could be done. But if it aint the issue whats the point bro. Its about time you got in there and dirty . With the age of your truck I would put one of Joey's modded HPOP in and be done with it. Your injectors will luv u for it and if you upgrade the sticks at a latter date you are half way there.
Nop. U dont have to go that far with the HPOP. He does a modded HPOP which is keeping up with my 250cc. Its only about 300 bones. And I cant help with a spare. Someone got on that boat b4 u. Maybe Clay can help or just pay the core.
