1987 Carb.
I think a few early 87 F250s did. But not any F150s. 86 F250s had a carb. It was a Holley/Motorcraft they were 4180s 4bbl. They were a similar to the 4160 Holley but different in many ways. They used a two stage power valve, different metering plates, etc. I can't remember exactly all the differences. I use to but when I got rid of my 86 F250 4x4 I forgot a lot.
Craig
Craig
Craig
Received 3,090 Likes
on
on
If you would of read my post after you asked I went into a little detail about the carb. Nice to see people read the complete posts when they have questions. I guess I need to quit wasting my time on low number posters.
on
on
The 4180 on the 351ho says 'Holley' on it. Call it a Motorcraft carb if you want but it's made by Holley for Motorcraft and has Holley cast into the fuel bowels. I have the original carb from my 87.
in 87 the 302 was EFI but the 351 and 460 were carb'd. Not sure if you could get the 351 in the F150/Bronco but I have one in a light duty F250 so I assume you could as it's in the same emissions class at the F150. I think the six went EFI in 87.
The 302 went EFI in 85 but you also had the 2bbl carb. While technically not available for 86 I've heard from some people with first hand knowledge that claim there were some 2bbl 302's made in 86. Also the 351 was available with a 2bbl till 85, and again, there may have been a few in 86. By 88 everything was EFI. At least with the normal line, there might have been some oddball chassis or cab/chassis stuff with a carb but you'd be looking at motorhomes/F450's/etc and such if they exist.
on
