eab flathead question - Ford Truck Enthusiasts Forums
Old 08-03-2013, 08:39 PM
ford1954250 ford1954250 is offline
ford1954250 is starting off with a positive reputation.
i just yesterday picked up a EAB flathead all complete not locked up can turn it over with a battery and spins great got to give it a tune up so it will run . . but my question is i was old it came out of a truck so was there a certain year for the EAB ??? and was it for a car or truck ????
Old 10-09-2013, 02:05 PM
52 4x4's Avatar
52 4x4 52 4x4 is offline
52 4x4 is starting off with a positive reputation.
It's been a couple of months since your post, so you probably already got an answer to your question somewhere. I just found this part of the forum today. After 60 years, your engine could have a lot of swapped parts on it. If you are going by the markings on the heads, I would say you've got a '52 - '53 engine that's probably from a car. They were usually painted red when new. A '52 truck engine was still an 8RT, but not sure about the markings on the '53 truck heads. I've got EAC heads on my '52 pickup and they're from a '52 Mercury.
Old 10-13-2013, 08:32 PM
55 f350's Avatar
55 f350 55 f350 is offline
55 f350 is a splendid one to behold55 f350 is a splendid one to behold55 f350 is a splendid one to behold55 f350 is a splendid one to behold55 f350 is a splendid one to behold55 f350 is a splendid one to behold
53 truck was still 8rt markings , my 52 customline was running an eab when new , but was replaced later in life by a 53 8rt . eab heads can handle .395 - 400 lift on the valves without machining , and have a small chamber of 69 or 71 cc for a boost in compression , so they are worth keeping . my 53 effie is running and 8ba short block that is soon to be freshened i hope , with the eab heads milled .010 for cleanup , and should be running like 7.8 compression .
EAB heads 1950FordF1 WTB - Parts & other 2 12-26-2014 01:52 PM
8BA and EAB parts r_reed Ford Truck Parts for Sale 2 11-06-2014 10:54 PM
Le$$on Learned... for 0BA, 1BA, EAB owners ALBUQ F-1 1948 - 1956 F1, F100 & Larger F-Series Trucks 63 10-17-2013 01:50 AM
Help with 1950 F1 Flathead V8 1964 f100 1948 - 1956 F1, F100 & Larger F-Series Trucks 18 04-21-2013 06:57 PM
flathead v-8 Rebuild Hints r_reed 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 10-21-2012 11:29 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
