Replacing cam bearings - Ford Truck Enthusiasts Forums
Old 08-03-2013, 08:39 PM
angrymade angrymade is offline
angrymade is starting off with a positive reputation.
Hello all,
I have somehow found myself on an engine building adventure. It all started when my oil pump seized due to a piece of broken valve stem seal that made it past the oil pump pick-up screen.
It's a 68' 429, in my 66' F100. Since I pulled the motor to install a new pump I decided to throw in a new cam. Today I pulled the cam to find all of my cam bearings are heavily scored and literally falling apart.
To make what could be an extremely long story short I'll get to the point.
Have any of you had to have new cam bearings installed? Did you have to tear the block completely down? (pull crank and pistons) And what was the rough cost?
Thank you in advance.
Jesse
Old 08-03-2013, 09:55 PM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
What do the rest of the bearings look like?
I would pull it down and do a rebuild as long as you are that far into it.
Where did all the material from those bearings go? Through the other bearings at some point!!
Old 08-04-2013, 12:59 AM
85e,
I had been thinking the same thing. I am going to just pull the rest of the motor apart and start from scratch. Thank you for the input.
Jesse
400 block cam bearings? and cam troubles 78_f150 1973 - 1979 F-100 & Larger F-Series Trucks 6 09-21-2011 09:55 AM
351m cam bearing guestion. triplecreek 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 6 03-31-2010 01:13 PM
FE Cam Bearing Question FordEdselFanatic FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 19 02-13-2009 01:12 PM
351M No Oil Pressure - AT WITS END!!!!! JCoggin 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 10 11-14-2007 12:16 PM
Cam Bearings danlee 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 14 10-30-2007 10:39 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
