Replacing cam bearings
Hello all,
I have somehow found myself on an engine building adventure. It all started when my oil pump seized due to a piece of broken valve stem seal that made it past the oil pump pick-up screen.
It's a 68' 429, in my 66' F100. Since I pulled the motor to install a new pump I decided to throw in a new cam. Today I pulled the cam to find all of my cam bearings are heavily scored and literally falling apart.
To make what could be an extremely long story short I'll get to the point.
Have any of you had to have new cam bearings installed? Did you have to tear the block completely down? (pull crank and pistons) And what was the rough cost?
Thank you in advance.
Jesse
Jesse
rpatrick
06-16-2011 08:06 AM
66shortbed
04-08-2010 01:53 PM
bikerwolfie
05-21-2002 05:51 PM
FE427TP
05-10-2001 04:52 AM
