1999 F-250 LD 5,4 what is the hole at back ofthe upper intake manifold
There is a hole on the back of the upper intake manifold, just below the back of the throttle body, is a vacuum hose supposed to be attached here? Have a serious vacuum leak, no coolant loss, no overheating, just had cop's and spark plugs done, now she backfires, stalls and will not stay running, mech. says its an intake gasket but the gasket and lower intake manifold look new.
Any ideas?
Thanks , Pete, I am nowhere need mechanically inclined but willing to learn
Any ideas?
Hey Colonel, looks like the hose from the pcv is about 10 inches long and runs into a 3 way junction just above the right valve cover, does not go all the way round back! Don't know if the port on the back of upper intake manifold was maybe blocked off and the plug came out? Does not look like a normal set up, I did read someone else had a similar experience and blocked off the rear port completely. I only bought the truck a month or so ago and have not used it much.
I will snap a pick in the morning.
Thank you sir.
Thank you sir.
laxxx
1997-2006 Expedition & Navigator
13
05-22-2022 01:44 PM
CraigB 1224
1983 - 2012 Ranger & B-Series
01-25-2011 02:14 PM
AndyCnsocal
10-20-2003 08:34 PM
