1996 F150 cltutch issues
Just registered but have used the site for info for years. Replaced my clutch slave cylinder last Nov for the second time since i bought it in '01. Clutch went out again this week so i replaced the master last night. Still have no pressure after bleeding the system. Pressing the clutch it stays on the floor without help but then springs out. Is it the slave again? What other issues could there be in that system? Any help would be appreciated. '96 F150 with the straight 6 and manual trans with 4x4.
Is there any fluid leaking from the slave inside the bellhousing? If not it sounds like you have a lot of air.
Do a gravity bleed. Loosen the bleeder, remove the cap, crack a beer and watch the level slowly go down, adding as needed. When you finish your beer, bleed as normal. This worked on my explorers and rangers with the stubborn master cylinders.
brown 4x4
11-15-2009 06:31 PM
classicfordfreak
01-11-2006 09:09 PM
lilymflower
11-15-2004 04:33 PM
1996F150kid
01-12-2004 10:57 PM
