NO BOOST HIGH EGT's!!!! - Ford Truck Enthusiasts Forums
Old 08-02-2013, 08:33 PM
99F350bigorange 99F350bigorange is offline
99F350bigorange is starting off with a positive reputation.
I've been on here a time or two before with this issue trying again for some new ideas maybe. I don't have any boost leaks or exhaust leaks. MAP sensor is good wastegate works properly and I wired my EBPV open. Still cannot build over 10psi of boost and my EGT's area little high when I get on it. Anyone got any ideas?
Thanks in advance.
Old 08-02-2013, 09:05 PM
A/Ox4's Avatar
A/Ox4 A/Ox4 is offline
9 ECHO 1
A/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputation
Have you looked at your compressor wheel?
Old 08-02-2013, 09:08 PM
JOHN2001's Avatar
JOHN2001 JOHN2001 is offline
JOHN2001 is a splendid one to beholdJOHN2001 is a splendid one to beholdJOHN2001 is a splendid one to beholdJOHN2001 is a splendid one to beholdJOHN2001 is a splendid one to beholdJOHN2001 is a splendid one to beholdJOHN2001 is a splendid one to beholdJOHN2001 is a splendid one to behold
What exactly are you calling "a little high"? And you have verified with a boost leak decter no leaks including the orange boots on the spyder?
Old 08-02-2013, 09:11 PM
Quote:
Compressor wheel is good. Yes no leaks even the orange boots. When I get on the interstate on the on ramp, empty, I can hit 1200 1250 with no problem and its still climbing but I don't let it go any higher.
Old 08-02-2013, 09:52 PM
JOHN2001's Avatar
Is the truck tuned? If so what tune are you running in while doing that? Also is that wot?
Old 08-02-2013, 09:54 PM
Not quite wot. Its on race tune, eco if your nice to it, edge evolution chip. This never use to happen but has been ever since I changed the bearings in the turbo.
Old 08-02-2013, 10:20 PM
JOHN2001's Avatar
What kind of boost are you seeing?
Old 08-02-2013, 10:22 PM
9-10 lbs most
Old 08-02-2013, 10:55 PM
JOHN2001's Avatar
I read that in your original post but forgot.... Do you have a fuel pressure gauge? Have you done the hutch mod?
Old 08-02-2013, 11:07 PM
No fuel pressure gauge and haven't done the hutch mod.
Old 08-02-2013, 11:26 PM
Kdr358's Avatar
Kdr358 Kdr358 is offline
Kdr358 is a splendid one to beholdKdr358 is a splendid one to beholdKdr358 is a splendid one to beholdKdr358 is a splendid one to beholdKdr358 is a splendid one to beholdKdr358 is a splendid one to beholdKdr358 is a splendid one to behold
Have you tried unplugging the edge and looked then? Edge tunes have been known to produce very high egt's.
Old 08-02-2013, 11:29 PM
Quote:
Same thing in stock mode with it plugged in or unplugged.
Old 08-02-2013, 11:32 PM
caedo's Avatar
caedo caedo is offline
caedo has a good reputation on FTE.caedo has a good reputation on FTE.
Quote:
Something got goofed up when you did that. Either incorrect reconstruction of the turbo, incorrect installation of the turbo on the engine, or some other thing which would be a crazy coincidence.
Old 08-02-2013, 11:35 PM
Quote:
That's what I was thinkin but I went back through the turbo again with help and everything seemed to be fine. Only other thing I could think of was up pipes so I've pulled manifolds and put gaskets and tightened everything also. I'm just lost.
Old 08-02-2013, 11:39 PM
caedo's Avatar
I'm just lost.
I HATE THAT FEELING!!
egt high at idle Superduty450 6.4L Power Stroke Diesel 13 05-29-2014 11:02 PM
Triple Gauge Pod going in my 94 factory turbo idi ford7.3l Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 0 05-09-2014 01:47 PM
Abnormally high egts need help austinpowerz101 6.0L Power Stroke Diesel 5 08-09-2013 03:47 PM
high egt Liquid10Rider 1999 - 2003 7.3L Power Stroke Diesel 5 07-09-2013 08:28 AM
Please help with HIGH EGT's renyren 1999 - 2003 7.3L Power Stroke Diesel 51 05-22-2010 12:20 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
