way too tight
way too tight
i am working on a 74 460 std bore and bearings all completely stock and i just replaced the main and rod bearings still all STD and torqued to spec and i cannot turn motor over even with a 3 foot cheater pipe i have loosened all rod bearings and it spins freely but if i tighten any one of the 8 rods i still cant move it crank was in perfect spec according to chiltons manual motor only has 80,000 miles on it but could that be why the bearings make it so tight? and yes i did pre lube everything..... i have not a single clue why its so tight but im hoping i can just use an old mini starter and hopefully it will crank it what are your thoughts?
dogmantra
11-25-2010 10:23 PM
nighthawk285
30
02-06-2007 02:33 PM
tweakingit
09-23-2003 03:21 PM
