Front sway bar bushings
08-02-2013, 06:21 PM
I was wanting some opinions as to whether these bushings are in need of replacement. These are on a 2006 Navigator.
Left side
Right side
Thanks!
08-02-2013, 10:08 PM
If you're hearing knocking sounds as you go over bumps then replace them, otherwise they're still good.
08-02-2013, 10:18 PM
I feel a slight pop under my left foot when the suspension shifts from braking to moving. Maybe its something else...
08-03-2013, 12:05 PM
Quote:
Originally Posted by
crazy96863
That's more likely a worn lower ball joint.
08-03-2013, 12:07 PM
Okay... I will check that out.
08-03-2013, 12:10 PM
If there is a grease fitting on the ball joint you could try adding some grease first, just in case it's been run dry.
08-03-2013, 12:32 PM
There is not... Its the original.
08-03-2013, 03:42 PM
Being originals I'd say they're due, assuming it was driven most of the time and it didn't sit around most of the year.
Y2KW57
1999 to 2016 Super Duty
32
12-06-2020 10:47 AM
robjs111
Ford Truck Parts for Sale
08-13-2013 12:01 PM
19-kilo
12-02-2011 08:24 AM
A/Ox4
10-03-2011 11:55 PM
sgrol
04-21-2006 05:56 AM
