Question for the motor Guru's
I'm going to be rebuilding a 292 and plan on really doing it right but what brand of gaskets would be best? I read on here where for a flat head the question of copper gaskets was brought up. I just want everything to be as good as I can do it, or does brand matter now-a- days? Any info would be great, thanks.
The steel or copper gaskets can be used to raise static compression due to the fact that they are thinner. If you want to burn high octane racing fuel, compression can be raised other ways, such as decking block, milling heads and using domed pistons. It is my opinion that engineers switched away from steel gaskets for good reasons. One typical scenario being that hot or even just "non-posted" heads may tend to distort and develop leaks with rigid steel gaskets. That being typed, I am presently using Fel-Pro Perma-Torque gaskets on the modest horsepower but torque-happy 292 that I'm putting together. It has a static compression of 8.5/1 and will be fine with 87 octane pump gas.
BTW: I've heard (read) nothing but good things about Best Gasket's seals.
Yblockheadcastingnumbers
85lebaront2
04-03-2015 02:53 PM
4starcstms
06-06-2007 12:37 PM
mswift
07-06-2006 03:51 PM
