95 f150 302 firing order? - Ford Truck Enthusiasts Forums
Old 08-01-2013, 08:48 PM
jrp79 jrp79 is offline
jrp79 is starting off with a positive reputation.
Changed the cap and rotor and put wires acording to the rad. Support and its wrong.the firing order for my truck is 15426378.door tag is dated 02-95.
Old 08-02-2013, 06:45 AM
lew52's Avatar
lew52 lew52 is offline
lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.
Quote:
...The firing order on the 95 is 13726548 , if it uses the older order i suspect some one changed the motor at some point ....
Old 08-02-2013, 10:12 AM
What changes the firing order.is it the cam and crank?
Old 08-02-2013, 10:16 AM
lew52's Avatar
....The firing order changed in 94 when they went to the roller cams , so anything 94 + has the roller cam with the new FO....
Old 08-02-2013, 10:21 AM
Quote:
Mustangs 86 and newer had roller cams so ford started making them in 86
Old 08-02-2013, 10:41 AM
lew52's Avatar
.....But the trucks didn't get the roller cams till 92 then in 94 they went to the bigger roller cam with the new order , the HO mustangs all had the roller cam ...
Old 08-05-2013, 10:29 PM
nflfreak43's Avatar
nflfreak43 nflfreak43 is offline
nflfreak43 has a good reputation on FTE.nflfreak43 has a good reputation on FTE.
92's and after trucks have the 13726548 which is the 351 firing order before 92 they had the older 289/302 FT firing order.. Mustangs had the 351 FO STARTING in 86..
Old 08-06-2013, 01:07 AM
pnp522 pnp522 is offline
pnp522 is starting off with a positive reputation.
Quote:
Firing order was changed in 94. 92-93 trucks are roller cam with the older 154 firing order.
Old 08-06-2013, 04:47 AM
nflfreak43's Avatar
Fairly certain they did not... I've pulled apart several 92/93 truck 302's and all have been 351 firing order if I remember.. I know 1000000% my old one in my truck was...
Old 08-06-2013, 05:46 AM
lew52's Avatar
I have never seen or heard of a 92 302 with the F4TE roller cam ...?
Where is MAP sensor located on 94 F150 5.0? countryboywatts 1987 - 1996 F150 & Larger F-Series Trucks 10 01-02-2016 05:35 PM
firing order bbussman40 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 3 07-09-2012 11:55 AM
1968 ford f-600 cylinder and firing order kgh Large Truck 2 04-01-2012 11:01 PM
93 f-150 motor swap (different firing order) bakes298 1987 - 1996 F150 & Larger F-Series Trucks 10 02-24-2012 07:32 PM
E303 in 95 5.0? TheTowingCowboy Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 12 11-08-2011 08:25 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
