Does it just beep if someone is sitting in the seat without their seatbelt buckled????
it doesn't have that pretensioner feature if that's what you're asking. i know the RH crash sensor is bad as the light was flashing 4-4 but i'm just wondering if any adverse effects from unplugging the control module to stop the freekin beeping...
Sounds like the passenger side module is now disabled. Your insurance company, or State Inspection may not be happy with this, so maybe consider a visit to a salvage yard for the replacement part/s needed, unless they require new parts for the reliability factor.
no passenger side airbag on mine just driver's side. i know the RH crash sensor up by the radiator is fubar'd...
hopefully the inspection won't reveal as for a '97 they don't hook up the obdii system to their computer because it's too old for emissions. time will tell.
so i can assume the srs system is disabled now right? since the control module is unplugged...
Yup the computer agrees with you, via its 44 code, that the front passenger side crash sensor mounting is faulty. Just replace it & you'll have your air bag protection back.
