2009 Navigator - Factory Keypad Code - Ford Truck Enthusiasts Forums
2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Old 08-01-2013, 07:13 PM
jurban91 jurban91 is offline
jurban91 is starting off with a positive reputation.
Hi everyone,
I am trying to find the factory keypad code for my 2009 Navigator L.
Been looking around the forum for a few days. I have tried to look into the fuse-box located under the glove compartment area on the front passenger side as this thread stated: http://www.ford-trucks.com/forums/87...ntry-code.html
I found the sticker, which says "FoMoCo". The only 5 digit code I found was the "Date Code". That code didn't work.
Is there any other place where I can look?
Any help would be welcome.
Thanks.
Old 08-01-2013, 07:25 PM
JWC 3's Avatar
JWC 3 JWC 3 is offline
JWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputation
They use to be on the keyles entry module . My 04 mounty was that way . It was on the pass side rear behind a trim panel . Not sure on yours though . If you can locate the module it may be on it . Hope that helps .
Old 08-01-2013, 08:05 PM
Hm, I have no idea where the keyles entry module is situated. Ill try to look around on the internet. Hopefully someone on this forum can point me in the right direction.
Old 08-02-2013, 02:46 PM
alwaysfords41's Avatar
alwaysfords41 alwaysfords41 is online now
alwaysfords41 is gaining momentum as a positive member of FTE.
Depending on what you read, some say it was removed from under the dash after 05, then others point to the label you show in the thread you linked to. You may want to give it another try and make sure you are hitting the keys firmly in case one is sticky.
Old 08-05-2013, 07:51 PM
teepee542's Avatar
teepee542 teepee542 is offline
teepee542 is starting off with a positive reputation.
on my 12 expedition it was on the back of the module that is behind the kick panel on the passenger side. I remove the sill plate trim and the kick panel. I also had to remove the screws holding the module in so that I could pull it back and get the code. A lot of effort but it paid off in the end
Keyless entry/doorpad question MackGuy Expedition & Navigator 4 11-28-2016 10:27 AM
Factory 5-digit keypad code location shotgunz 2009 - 2014 F150 29 05-11-2016 02:25 PM
stick on keypad in fuel door? flixden 2009 - 2014 F150 18 02-27-2012 03:40 PM
2001 Navigator keypad code 79man Expedition & Navigator 2 11-01-2007 12:06 PM
factory keypad code drillmaster 6.0L Power Stroke Diesel 3 02-25-2007 08:43 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
