Best oil & filter 03 Expedition - Ford Truck Enthusiasts Forums
Old 06-13-2003, 11:08 AM
heislerj heislerj is offline
heislerj is starting off with a positive reputation.
Question Best oil & filter 03 Expedition
I just purchased a 2003 Expedition, and looking for the best protection for the engine, I plan on keeping this one for a long time. In my old Expedition “2001” I used Pennzoil 5W20,Meets Ford’s specification’s (Ford specification WSS-M2C153–H.), with Fram oil filter. I have done a lot of research “internet”, and found that Fram’s quality is not that good. I change the oil every 3,000 miles and have it narrowed down to Pennzoil 5W20, with Wix oil filter P/N51372 $6.25, auto parts store, or Pennzoil 5W20, with Motorcraft oil filter P/N FL820-S $7.75, Ford Dealer. I know that everyone has differing opinions, but will this provide the best protection? Or better then OEM?
Thanks, for all the info
Jeff
Old 06-13-2003, 12:25 PM
WillieTD's Avatar
WillieTD WillieTD is offline
WillieTD is starting off with a positive reputation.
If you're changing your oil every 3,000 miles it's not really going to matter too much what oil brand you are using. As long as it meets oem specs then you're OK. I use Mobil Drive Clean 5W30 but I'm switching to Mobil 1 10W30 tomorrow, actually.
I use the Motorcraft filter. It is the same filter as the Purolator Pure One which is generally regarded as one of the best. I would definitely stick with Motorcraft.
Read this: Engine Oil Filter Study
Old 06-13-2003, 01:04 PM
WillieTD;
Thanks for the reply. Both look good, the only question, or comment, is the string? Kind of strange.
Thanks again.
Jeff
Old 06-13-2003, 03:43 PM
mikemc's Avatar
mikemc mikemc is offline
mikemc is starting off with a positive reputation.
Motorcraft filter and either Motorcraft or Castrol GTX 5w20 (two of the "thicker" 5w20's made). Enjoy your new Expy!
Old 06-13-2003, 03:56 PM
WillieTD's Avatar
Quote:
Originally posted by heislerj
WillieTD;
Thanks again.
Jeff
String? I don't understand what you mean.....
Old 06-13-2003, 07:54 PM
mikemc's Avatar
I think he means the string used to hold the media together during production, it can be seen in pictures of cut open filters. Na, that lil' ole string don't hurt nothin'.
Old 06-13-2003, 08:11 PM
Flash Flash is offline
Flash is gaining momentum as a positive member of FTE.
heislerj,
The 5w=20 Pennzoil and the Castrol GTX has about 50 ppm's of moly in the bottle but the Motorcraft does not. The only time moly is of importance is when things get crazy in the engine compartment and the only lubrication left is the barrier lube. I have yet to see a 5w-20 Ford speced oil produce a bad used oil analysis. The stuff is exremely well built. If you want your engine to run cleaner, longer, stick with the Ford approved 5w-20, even in the extremes.
Old 06-14-2003, 07:45 AM
Thanks for the information:
I did mean the string in the picture.
Sounds like Pennzoil 5w20 and Mortorcraft filter, will be my choice.
Thanks again for the information...
Jeff
Old 06-17-2003, 01:38 PM
02PSD4ME's Avatar
02PSD4ME 02PSD4ME is offline
02PSD4ME is starting off with a positive reputation.
I do n't know or not if thare any oils YET that meet the Fords spec WSS-M2C 153H 5w20 oil.
Old 06-19-2003, 01:08 PM
02PSD4ME's Avatar
Wal-Mart has the Motorcraft oil filter for $2.65 and the 5w20 semi syn for $1.77 Qt
Old 06-19-2003, 01:34 PM
WillieTD's Avatar
That's even cheaper than my WalMart. A friend of mine bought Mobil1 at Advance for just under $5.00/quart and I had to scold him since he can get a 5 quart jug at WalMart for $18.88. WalMart's great for some things.
Old 06-20-2003, 03:59 AM
wafordtech wafordtech is offline
wafordtech is starting off with a positive reputation.
Stick with the motorcraft all the way. The 4.6/5.4/6.8 engines are pretty picky. BG company showed our ford dealership independent test results of all major brand oils. Motorcraft was #1 by a long ways. Walmart has motorcraft filters cheaper than dealer cost, and my walmart's even have actual M/C oil. I use M/C 15W40 diesel oil in my 390. GOOD STUFF!!!
Shell rotella owned by pennzoil??? 429law 1999 - 2003 7.3L Power Stroke Diesel 9 10-02-2009 06:13 PM
What is the best oil filter to use on the 5.4 jdhudall Modular V8 (4.6L, 5.4L) 47 03-12-2009 10:09 AM
MC Synthetic Blend vs Pennzoil Platinum ExpySport Oil & Lubrication 21 01-12-2009 06:43 PM
78 351M Oil recommendations please? Shamus Oil & Lubrication 22 05-18-2008 11:09 PM
Labels selling Racor full flow filters Swift193 6.0L Power Stroke Diesel 13 05-25-2007 11:10 AM
Tags
03, 2003, 2006, 5w20, colorado, expedition, expidition, filter, ford, fram, motorcraft, oil, oild, older, switching
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
