F250 Towing? - Ford Truck Enthusiasts Forums
F250 Towing?
Old 08-01-2013, 03:19 PM
Killgore's Avatar
Killgore Killgore is offline
Killgore is a splendid one to beholdKillgore is a splendid one to beholdKillgore is a splendid one to beholdKillgore is a splendid one to beholdKillgore is a splendid one to beholdKillgore is a splendid one to beholdKillgore is a splendid one to behold
F250 Towing?
Hey I have my F250 Camper Special w/a 390. Now that she is almost done I am starting to think about what is safe to tow with. It has the bumper/tow hitch rear bumper.
Old 08-01-2013, 04:18 PM
brian1080's Avatar
brian1080 brian1080 is offline
brian1080 has a good reputation on FTE.brian1080 has a good reputation on FTE.
what are you wanting to know? my f150 with 400 pulled everything I needed fine. Just make sure you have a good receiver rated high enough, good wiring for the trailer plug and strong springs
Old 08-01-2013, 07:32 PM
Killgore's Avatar
I'm more or less wanting to know safe tongue weight on the factory bumper. I can post a pic of it later
Old 08-01-2013, 10:10 PM
brian1080's Avatar
can't help ya there. I've seen people pull some heavy loads on bumpers, but I've seen a lot of bent bumpers. Personally the only thing I'll ever pull with a bumper is single axle trailers. Once it gets to car size trailers, I won't risk it. Receivers are easy to find and even easier to install. 6 holes drilled (if they aren't already there) and it's in.
Old 08-02-2013, 01:28 PM
V10man's Avatar
V10man V10man is offline
V10man is gaining momentum as a positive member of FTE.V10man is gaining momentum as a positive member of FTE.
I would say 2000-3500 pounds. Max.
Old 08-02-2013, 03:24 PM
wotan's Avatar
wotan wotan is offline
wotan is starting off with a positive reputation.
I wouldn't put more than 400/500 lbs of tongue weight on a bumper hitch.
Old 08-02-2013, 03:43 PM
Killgore's Avatar
Alright, I will only do light weight pulling until I get a reciever
Bumper guard questions... LawnDoc89 1999 to 2016 Super Duty 1 12-17-2016 10:12 AM
Tow with uhaul an tow bar Shenna Tipton Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 5 09-22-2015 01:19 AM
F100 towing Johno.h 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 12 07-12-2015 11:27 AM
towing with a step-bumper ? Leef250 1973 - 1979 F-100 & Larger F-Series Trucks 6 06-26-2015 11:56 AM
Max bumper hitch weight griff28 1961 - 1966 F-100 & Larger F-Series Trucks 4 04-07-2015 06:45 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
