It's August already? NOOOOOO!
#91
Well tomorrows the last day of vacation for me. Can't complain to much since I have the 20th-29th off of this month also. Plan on putting my bump stops and shocks on. They are scheduled for delivery today.
While I'm out tonight I might try my luck with the powerball lottery.
Fingers are crossed for ya AL!!
But just a heads up, you have competition
#93
#96
#98
#99
#100
#102
Ok so got the truck nosed into the garage and jacked up both sides. (Note the truck is not jacked up in picture, I definatley need a bigger garage can barely get tires on concrete)
Both tires are rock solids no movement.
So continued the investigation since I had some time finally. Pulled the lockout on each side passenger side looks good but the drivers side is toast. Totally shredded.
The passenger side grinding is due to a grease fitting on the upper ball joint, Driver's side had one which is ground down to nothing.
The driver's side outer shaft has a lot of movement up and down as well as in and out?
#104
just as i figured. a new hub, needle bearing, and all the seals and you should be good. i think i had about $100 into each side for all the seals and a needle bearing (bearing from napa... ford will tell you you can't replace just the needle bearing and have to do the whole unit, not true. i'll see if i can find the napa p/n for you).
guess it's a good time to upgrade your hubs too! you have ESOF?
