EATC problems on 96 Explorer Eddie Bauer 5.0L - Ford Truck Enthusiasts Forums
Old 07-31-2013, 01:38 PM
oldmanXJ oldmanXJ is offline
oldmanXJ is starting off with a positive reputation.
My AC isn't working on my 96 Eddie Bauer 5.0L Explorer. Mechanically everything is fine. The problem is that there is no drive coming out of the EATC to activate the clutch on the compressor. Both the high and low switches are fine. I can probe the connector on the output of the EATC and drive the purple wire with 12v and the compressor clicks on and I get cold air. I have run the built in self test and got 888 back so it isn't showing any problem.
I was wondering if a bad cabin temp sensor could cause it to not turn on the AC? I am going to go to the heat setting and crank down the set point to see if the heater will turn off. Does anybody have any experience with this? Is there anything else I should check. I have the real Factory wiring/troubleshoot CD for 96, but it won't load on my Win7 laptop.
I'm an electrical engineer and was wondering if there is an output drive transistor that might be blown. Does anybody have schematics for the EATC internals?
Heater/Air control problem cliffhanger_18 1999 - 2003 7.3L Power Stroke Diesel 18 11-03-2014 06:54 PM
A/C Compressor Won't Engage - Interior Temp sensor? hozee4 Cooling, Heating, Ventilation & A/C 31 08-07-2013 07:18 PM
Problem with EATC on 96 Explorer EB oldmanXJ Explorer, Sport Trac, Mountaineer & Aviator 4 08-02-2013 06:50 AM
99 Exped Front Blower Problem wmingari 1997-2006 Expedition & Navigator 13 07-13-2013 01:03 PM
EATC codes 12 and 49 Lorii 1997-2006 Expedition & Navigator 2 03-15-2007 07:01 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
