97' F450 Dana 80 rear disc pads
This will be my first time changing the disc pads out on the dana 80 rear and wondering the correct way to do...looks like theres no bolts but upper and lower "Pins", do I use a flat nose punch or is there a Special tool for getting pads out....going to dive into this today
Thanks for the help
Black oak tree service
Thanks for the help
Don't put the punch in the center, it's rubber... Use a wide nose punch to start with and work each metal part of the slide into the housing to get it started, then use a longer to knock it through..
I have a punch that has a square shank that fits right in the slides, I use the small end to get it started then turn it around to the square part and go for it..
Clark17
05-27-2017 08:00 PM
sand_fiend
05-09-2013 06:43 AM
jcmac
11-12-2001 07:24 PM
