fuel filter for 2000 ranger - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 06-13-2003, 08:46 AM
manirron manirron is offline
manirron is starting off with a positive reputation.
Cool fuel filter for 2000 ranger
hi:
I am new to this forum and need some help..I have a 2000 ford ranger with a 3.0 liter 6 cyliner engine...Does anyone know where the fuel filter is and if a special tool is required??...I have tried to trace the fuel line but cant seem to find the filter...
..please email me at manirron(No Email Addresses In Posts!)
thanx if anyone can help me
Old 06-13-2003, 09:40 AM
Rockledge's Avatar
Rockledge Rockledge is offline
Rockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to behold
Hello, welcome to Ford Truck Enthusiasts!
You should try using the search function ...there have been several recent threads in this forum on the subject of changing out a fuel filter.
In the meantime, here is something to get you started:
Changing Ranger Fuel Filter
Old 06-13-2003, 09:49 AM
Thanx for the reply..I did do a search after I posted my question..
I may get a manual anyway..thanx again !
Old 06-13-2003, 10:16 AM
Rockledge:
another reason I posted "where is the filter?" is because the auto parts store all seem to say there are 2 different filters that could be used for my ranger's model and year.and they could be in different places..ever heard of that?
Old 06-13-2003, 10:25 AM
WXboy's Avatar
WXboy WXboy is offline
WXboy is starting off with a positive reputation.
Every 90s model or newer Ford truck I've ever seen has had the fuel filter located next to the frame, on the inner side, under the driver's side door. A special tool is required to disconnect it from the fuel line, but that tool can be bought at auto parts stores usually.
Old 06-13-2003, 10:26 AM
ok thanx!!!
Old 06-14-2003, 07:25 PM
greenpus greenpus is offline
greenpus is starting off with a positive reputation.
I think the auto parts store you go to must be smoking crack or sumthing. There is only one fuel filter and it is used on all three models of that year. It does not matter if you got the FLEX engine or not they all use the same filter.
FG-1004
Quote:
Originally posted by manirron
Rockledge:
Old 06-14-2003, 07:46 PM
Bob Ayers Bob Ayers is offline
Bob Ayers has a good reputation on FTE.Bob Ayers has a good reputation on FTE.Bob Ayers has a good reputation on FTE.
On my 1999 3.0L FFV, the fuel filter is a different P/N from the
NON-FFV 3.0L.
Old 06-14-2003, 08:53 PM
I just checked the Motorcraft website, and found the following:
Fuel filter for 2000 NON-FFV 3.0L: FG-1071
Fuel filter for 2000 FFV 3.0L: FG-1033
So, according to Motorcraft, the fuel filters are different for a
2000 FFV 3.0L.
Old 06-14-2003, 10:28 PM
JoggingGuy's Avatar
JoggingGuy JoggingGuy is offline
JoggingGuy is starting off with a positive reputation.
I have a 2000 Ranger 3.0L FFV engine and I put a new fuel filter in a few days ago. It was on the inside of the frame under the driver's side door. I didn't even have to jack up the truck to swap it out.
My owner's manual calls for a FG-1002 and that is the part number on the old one. I replaced it with a Wix 33652. These filters have two connectors on the input side and one on the output side. It only took a small screw driver to pop the clips off and release the connectors.
Old 06-14-2003, 10:44 PM
Rockledge's Avatar
It sounds to me like Ford is doing its best to confuse us again!
Old 06-15-2003, 03:43 AM
well I found the filter and replaced it quite easily!!...I just needed a flat screwdriver to pop the clips off and crescent wrench to remove the one mounting nut..as fas as my auto parts store smoking crack,well this IS south florida..
now I just need to found out what is causing a clunking sound
front driver side.. I have seen some posts here that it could be the radius arm or something like that...I am hoping it is the shock absorber..should a stock shock go bad by 60,000 miles?
Old 06-15-2003, 01:30 PM
mrwizard's Avatar
mrwizard mrwizard is offline
mrwizard is starting off with a positive reputation.
Give the truck the "bounce" test to check the shocks. No reason why the stock ones couln't go bad in 60K.
Did the guys at the parts store have to take a vote and count the hanging chads to figure out which filter you needed?
Old 06-16-2003, 07:59 PM
Ken00's Avatar
Ken00 Ken00 is offline
Ken00 is gaining momentum as a positive member of FTE.Ken00 is gaining momentum as a positive member of FTE.
The filters are different because the E-85 is more corrosive and Ford did switch the connections, either 99 or 00.
Old 06-17-2003, 08:38 AM
they switched the filter in 2000. The 99 has 2 connectors and the 2000 has 3. Like I said the filter is the same for all three engines. It doesn't matter if you use Flex fuel or not. The filters are made from all plastic on the 2000 model so corrosive fuel isn't a problem.
fuel injected 1990 f250 5.8 transplant to 1988 ranger chalvata Ranger & B-Series 12 02-16-2012 08:10 PM
1999 Ford Ranger 3.0l Whipple Supercharger mjpennella Ranger & B-Series 2 09-07-2007 11:06 PM
V8 Ranger Rear Axle Suggestions hermann9kwc Ranger & B-Series 4 12-02-2004 11:42 PM
changing spark plugs on mazda b4000 mldx20 Ranger & B-Series 2 07-05-2003 09:01 PM
Junkyard jewel 351w 77sFORDPLAY Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 27 02-12-2003 09:19 PM
Tags
2000, changing, fg1002, filter, ford, fuel, gas, motorcraft, nc, number, part, ranger, remove, sale, xlt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
