Drive shaft problems :(
Old 07-30-2013, 07:42 PM
SuperDuty93's Avatar
SuperDuty93
SuperDuty93 is offline
My 59 f100 has a c6 with a 390 in it currently. Someday it will have a t56 but for now I'm putting in a 4 speed instead of the auto. My problem is that the c6 is way longer then the NP435 so my driveshaft is now to short by a lot. What's my best bet? I assume my only option is a new driveshaft but what's that going to cost?
Old 07-30-2013, 07:57 PM
spurredon's Avatar
spurredon
spurredon is offline
Maybe $120.
Old 07-30-2013, 08:51 PM
SuperDuty93
That cheap? Where would I go to get one?
Old 07-30-2013, 11:38 PM
Beechkid's Avatar
Beechkid
Beechkid is offline
check with the local hot-rod guys & there should be a good local driveshaft shop in your area...........
Old 07-30-2013, 11:54 PM
SuperDuty93
There is one 3 min from my house. But a friend needed new bearing put into his driveline and to install the 3 it was like $50. And they didn't even put the driveshafts back in the truck. That's why im questioning the price of a whole driveshaft.
Old 07-31-2013, 06:22 AM
3414's Avatar
3414
3414 is offline
Ask them for an estimate - show them the old driveshaft and the yoke for the 4 speed you are going to use, as well as the length needed. $50 to replace a bearing is not bad.
Another option is finging a junkyard driveshaft that is longer and having it shortened.
Old 07-31-2013, 07:44 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Makes up new drive shafts, has zillions of used: SoCal Truck Wrecking - 8229 S. Alameda St. - Los Angeles 90001 - 323-587-3144 - Ask for Juan or Marty.
Most autoparts stores & FoMoCo sell driveshaft center supports as kits. Includes bearing/shims/brackets/U-shaped rubber support.
william16339
08-10-2017 11:01 AM
SuperDuty93
09-17-2013 09:12 PM
67F250RET
03-28-2013 03:21 PM
HardFordCore
10-17-2003 11:03 PM
Torque1st
09-21-2002 05:24 AM
Quick Reply: Drive shaft problems :(
