Some trouble with Sync/MFT - Ford Truck Enthusiasts Forums
Ford In-Vehicle Tech Discussion area for Ford Sync, Sync AppLink, MyFord Touch, Ford Supplied SiriusXM Radio, Ford Work Solutions, etc.
Old 07-30-2013, 11:30 AM
bryyce62's Avatar
bryyce62 bryyce62 is offline
bryyce62 has much to be proud ofbryyce62 has much to be proud ofbryyce62 has much to be proud ofbryyce62 has much to be proud ofbryyce62 has much to be proud ofbryyce62 has much to be proud ofbryyce62 has much to be proud ofbryyce62 has much to be proud of
I've got a '13 SD Lariat with the newest sync/My Ford Touch system.
I noticed last weekend that when I press the voice command button on the steering wheel, the the prompt that asks me to 'please say a command' does not work anymore. The dash display acts like it is waiting for a command, but when I say something, I get no response.
Is there a master reset that I can utilize before making an appointment at the dealer?
Thanks,
gw
Old 08-04-2013, 01:26 PM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
There is a "master reset" in the settings menu. How to Perform a Master Reset | MyFord Touch | Ford.com
This will wipe out any customizations you've done, as well as the bluetooth pairing to your phone.
I found that even after multiple master resets, and pulling the MFT fuse, and even the "delayed reboot" available on the net, pulling the battery cable for an hour fixed a problem I was having with SiriusXM Traffic and my navigation system (this is on my Taurus). In my case, there was something going on between the satellite radio, and the navigation system, and the MFT wasn't really the problem.
With your issue, I'd say a simple MFT reboot might help. Pulling the battery cable is probably the easiest way to do this. In my Taurus, the MFT fuse is buried under the dash somewhere. In your truck, it might be very easy to get to. If so, I'd pull the fuse for 10 minutes and see what happens. Otherwise, disconnect for battery.
Report back
Old 08-05-2013, 10:33 AM
bryyce62's Avatar
Report back
Thanks Art,
I was able to do a master reset thru the system menu on the radio. The voice prompt came back but then I had some trouble pairing my phone again.
Long story short, got some technical help from my son-in-law (a techno geek) and he got the phone to link back up to Sync.
According to Ford's Sync website, there is a major upgrade happening to the Sync system. Maybe this will fix the bugs I've been having in my rig.
Thanks again. I never considered pulling the fuse or disconnecting the battery. It'll be something I try next time I run into a problem.
Old 08-06-2013, 08:58 PM
Krewat's Avatar
Yep, got version 3.6 today and installed. No big differences noticed yet, but ... bluetooth stereo seems more responsive.
Old 08-07-2013, 08:01 PM
GuyPavelo's Avatar
GuyPavelo GuyPavelo is offline
GuyPavelo is starting off with a positive reputation.
How did you upgrade sync? I cant figure out how to make it connect to the net via my iphone or anything... Not sure how to do much on it really. Dealer started to talk about it but not sure he even knew how the heck to use it. Id love to know how to get the traffic warnings and things work... As well as how to take a detour!
Old 08-08-2013, 10:31 AM
bryyce62's Avatar
Use the link to get to the Ford Sync update. Register, if you haven't done already.
Follow the instructions for the update. Good luck.
Get Support and Manage Your SYNC Account | Syncmyride.com
Old 08-08-2013, 12:13 PM
GuyPavelo's Avatar
Aaaah! Thank you so much Bryce!
Old 08-08-2013, 12:43 PM
Krewat's Avatar
Just so you know, this got moved to the new IVT forum.
Vehicle health report rtazz17 6.7L Power Stroke Diesel 22 11-04-2014 02:53 PM
Command Start Cranks but no fire! SMIGGS 1999 - 2003 7.3L Power Stroke Diesel 1 02-14-2014 08:43 PM
Voice commands not available with USB device Big-Red-Lariat 2009 - 2014 F150 7 02-13-2014 12:17 PM
TSB for 2011 VOICE RECOGNITION INTERMITTENT Big-Red-Lariat 2009 - 2014 F150 0 11-09-2013 03:45 PM
Sync Apple Itouch Issue CBBeaty 6.7L Power Stroke Diesel 10 11-01-2013 12:36 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
