93 F150 4.9 No start
1993 4.9 F50, auto trans. The truck suddenly shut down while driving down the road. Pulled to the side and tried to restart....nothing! checked around, found no spark, and no fuel. Checked fuses, and found the #9 underhood 20 amp maxi fuse was blown. Replaced the fuse drove a short distance and then the above happened again! It is my understanding that this fuse is for the PCM? and has some direct relations, to the relay nearest the driver fender in the under hood fuse panel...correct? This is the PCM relay right? So what would you guys think I should be checking? Anyone have a good wiring diagram? Or know the circuit protected by this fuse? Thanks in advance to any help...I sure need it!
Okay it seems this thing will idle all day long, but you can only drive a short distance and then it will shut down and the fuse will be blown in the under hood relay center, #9 position. Does anyone know what all is on this circuit? I am at wits end here! According to what little I have been able to find on this, that fuse is for the PCM? Anyone have any input on this?
I hooked a scantool to it earlier because it seemed it shifted really early to me now that I have this problem, but all I came up with was a 332 which is for the EGR valve. I noticed that the relays both (fuel pump, and PCM) feel rather warm, I don't know if that is normal or not? I'll check red wire 361 end to end tomorrow, and try to see if there are any tests I can do on the components in this circuit.
Joshua A. Gaudette
07-15-2023 07:52 PM
lostislandguy
15
03-08-2023 01:04 PM
compucarnut
16
09-23-2016 08:42 AM
