5.4 spark plug replacement??? 's - Ford Truck Enthusiasts Forums
Old 07-29-2013, 10:33 PM
dentfxr dentfxr is offline
dentfxr is starting off with a positive reputation.
New guy here. Just bought a 2000 F150 7700 and am doing a slew of upgrades and repairs. I have seen several YouTube.com clips on replacing 5.4 spark plugs. From what I've seen and read on this subject I see the replacement plug of choice is Motorcraft. I just discovered the new design 1 piece Champion 7989 plugs that won't break apart when its time to replace them. Anyone installed these in their 5.4 and what do you think of their quality compared to the Motorcraft product? Thanks.
Old 07-30-2013, 07:55 AM
JWA's Avatar
JWA JWA is offline
JWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputation
For your year motor the newer style are NOT spec'd out----those are intended for the 3 valve heads. Use MotorCraft SP479's or the Auto Lite equivalent.
Too often in this forum its been proven the MotorCraft plugs work best in our engines.
I use nickel-based anti-seize and torque to 23 ft/lbs but some will disagree that's how best to do it.
ALSO check your COP boots, replace as needed even if they seem okay for the moment---this is an area often over looked which causes problems, sometimes more noticeable after new plugs are installed. I use an NAPA/Belden p/n 702418; USA made, about $5 each IIRC.
Hope this helps!
Old 07-30-2013, 07:19 PM
jprix jprix is offline
jprix is starting off with a positive reputation.
I just changed my out couple days ago. Motorcraft sp-479.
It wasn't a bad job as I thought it would be. I didn't see no other way but to lift the fuel rail up to get to the #7 coil bolt.
Old 07-31-2013, 08:50 AM
JWA's Avatar
JWA JWA is offline
Believe it or not the #7 & #8 can be removed without budging the fuel rail--seen it done in person I have!
It tends to require 1/4" drive extensions and ratchets though---with a bit of wiggling it can be accomplished.
I'm due to change plugs in an '00 with the 5.4 and will take photos of this process. Update to this post when that's finished.
Old 07-31-2013, 05:11 PM
BigBlue99's Avatar
BigBlue99 BigBlue99 is offline
BigBlue99 is starting off with a positive reputation.
#7 can be a skank. 7mm 1/4" wiggly socket is the way to go
Old 08-01-2013, 08:39 PM
Maybe my socket was too tall but there was no way it would clear the fuel pressure regulator and get a decent grip on the bolt.
It took me longer trying to work around the rail then lifting it.
If anybody does remove it,just make sure you have a pick tool to remove stuck o rings. 2 out of 4 was stuck in the fuel rail.
Old 08-10-2013, 07:51 PM
phillycincykid phillycincykid is offline
phillycincykid is starting off with a positive reputation.
just did my 2000 5.4 2 weeks ago....use motorcraft plugs. all the research ive done its the bast way to go. the torque is anyones opinion . plugs 7 and 8 are a bitch....i did not have to move fuel rail out of the way thou.
Broken spark plug 5.4l 3v Action410 Modular V8 (4.6L, 5.4L) 11 03-29-2016 11:15 AM
2009 5.4L Replacement Spark Plugs NewXer 2009 - 2014 F150 3 02-27-2014 07:51 AM
5.4 3v Spark plugs Bubba Jim Modular V8 (4.6L, 5.4L) 9 02-03-2014 10:45 PM
best spark plug? AppocAlexx Modular V8 (4.6L, 5.4L) 9 01-19-2012 08:41 PM
Iridium or platinum? lectricman 1997 - 2003 F150 12 10-08-2009 05:24 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
