Axel nut size
At least it looks like it's hexagonal. Albatross ('55 F500) has octagonal nuts. That definitely takes a special socket. I found a good hard octagonal socket on FleeBay.
It will spill a bit, you can minimize that by slightly "tipping" the axle. Change the seals when you close it up. I greased mine, help to keep from running dry before the lube oil makes it to cover the bearings.
powerstroker100
09-12-2010 02:48 PM
Glockem45
10-03-2009 03:40 PM
Wrecker
11-28-2004 12:45 AM
