Bedrug or more? - Ford Truck Enthusiasts Forums
Bed Covers, Tonneau covers, Toppers/Canopies & Bed liners Tonneau cover, caps, racks, canopies, shells, etc.
Bedrug or more?
Old 07-29-2013, 11:27 AM
Buck268's Avatar
Buck268 Buck268 is offline
Buck268 is starting off with a positive reputation.
Bedrug or more?
Purchased my truck used and it came with a BedRug fully lining the box. Now that is just fine as on the rare occasion where I'll haul something dirty I can easily throw a tarp in there to keep stuff nice but I was curious how well the bedrug will protect the paint from damage such as deep scratches or wearing through over time? It seems to be fairly secure and doesn't move around too much but I am half tempted to at least Herculine the tailgate under the bedrug just to be thorough- but is that overkill?
Old 07-29-2013, 03:23 PM
Turbo Dog's Avatar
Turbo Dog Turbo Dog is online now
Turbo Dog has a good reputation on FTE.Turbo Dog has a good reputation on FTE.Turbo Dog has a good reputation on FTE.
I've got a BedRug but I've only had it about 5 months. It doesn't seem to move around but I think it would still end up scuffing the paint underneath over time. That's not a problem for me because I don't worry about the paint in the bed of a truck...I just try to keep the exterior surfaces looking nice.
Underneath the tailgate part of the BedRug I added a piece of 1/8' thick plywood and a piece of closed cell foam from an old camping pad. That makes it much more comfortable to sit on.
Old 10-11-2013, 04:25 AM
brmccolley's Avatar
brmccolley brmccolley is offline
brmccolley has a good reputation on FTE.brmccolley has a good reputation on FTE.
no issues
other than lining up the bolt holes when reinstalling or the rust stains from the floor jack sitting on a wet spot. I much prefer the sound deadening from the padding when stuff is in the bed.
Old 10-11-2013, 06:10 AM
karlduke karlduke is offline
karlduke is starting off with a positive reputation.
Do the bedrug trap moisture? I'm just looking for personal experience/reviews before I decide to get one.
Old 10-11-2013, 06:54 AM
brmccolley's Avatar
Considering the fact
that I've got a Rollbak top, yes it tends to hold moisture because the top leaks. I don't daily drive my truck, so I have to check on it on the weekends to make sure the back doesn't get too wet and gets a chance to air out.
The Bed Rug can be a little trouble to clean after hauling wood or something messy only because I haven't used a tarp underneath the load. Otherwise, it's quite nice to have to protect loads, it's easy to slide objects, and it's kind to the knees while crawling on the bed in the garage to unload. It also increases the traction a bit for items that are in the bed so they don't move around as much in comparison to a bare metal bed.
It's about the easiest installation I've done on a vehicle.
Old 10-11-2013, 08:22 AM
Buck268's Avatar
I have a tri-fold top on mine with the bedrug and have not had any issues leaking so therefore no issues with moisture. The Bedrub marketing states a tonnaeu cover is not required and the fabric is an open weave, closed fiber design. I did wash it out once this year and noted that the fabric drained water and dried fairly readily.
Projector headlight retrofit 86F150302 1987 - 1996 F150 & Larger F-Series Trucks 26 12-30-2016 09:25 PM
86 step side freshen up 86f150step 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 38 05-17-2015 11:36 PM
what is this part jps47 1999 - 2003 7.3L Power Stroke Diesel 4 01-02-2014 06:02 PM
F350 TrailBlazer - Slide in camper on steroids! bigtexan99 1999 - 2003 7.3L Power Stroke Diesel 0 10-10-2011 06:46 PM
I had to do it! thejean Alberta Chapter 5 07-17-2011 02:42 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
