New Cam 5.8w - Ford Truck Enthusiasts Forums
New Cam 5.8w
Old 07-28-2013, 09:24 PM
killert killert is offline
killert is starting off with a positive reputation.
New Cam 5.8w
MY truck is a 1991 F250
Speed Density 5.8
I'm not new to working on cars, I'm a GM tech. But I'm new to Ford
I decided to hop up my truck a little bit so I bought a full exhaust, GT40 heads, and a Comp Cam 35-235-3, but after doing so reading I for the lobe separation might be to much for the speed density, What would the negative effects be of using this cam?
Old 07-28-2013, 09:58 PM
Conanski's Avatar
Conanski Conanski is offline
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
Rough idle and stalling, if it's a play truck you could probably live with it but if it's a daily driver it'll get on your nerves. The cam for this motor is the Crane 444232, produces a smooth idle with healthy gains across the board when paired with headers and exhaust.
Old 07-28-2013, 10:31 PM
Thanks for the quick response and advice. Ive canceled my order on the cam. I have had bad luck with crane cams... would the comp cam 35-255-5 compare? If not I'm still open to the crane cam. The truck isnt exactly a daily driver but needs to be reliable.
Also not looking to win races, just a good running stout motor.
Old 07-29-2013, 05:44 PM
Gonna take my chances with the Crane Cam.
Parts list of everything ordered or already here:
Gibson Supertruck Cat-Back
Magnaflow Cat+Y-pipe 93312
Gibson GP201 Headers
Lightning GT40 heads
ARP 154-3603 Head Bolts
Felpro full engine gasket set
Stage 8 locking header bolts 8913 ( These bolts are great, Have them on my firebird)
Comp Cams 3230 Timing chain
Comp Cams 502-16 Valve stem seals
Comp Cams 601-16 Valve stem locks
Comp Cams 768-16 Valve spring retainers
Comp Cams 942-16 Valve springs
Crane Cams 444232 Cam and lifter kit
Proform Smog pump eliminator 68110
And next week I'll order Crane Cams 44746-16 Rockers
Old 07-29-2013, 10:06 PM
V10man's Avatar
V10man V10man is offline
V10man is gaining momentum as a positive member of FTE.V10man is gaining momentum as a positive member of FTE.
Lots of $$ in exhaust. I would of used pacesetter long tubes, into a Y then single 3" cat, 3" muffler then out the side. Probably cost just what those Gibson headers cost alone.
Old 07-29-2013, 10:28 PM
jseim44's Avatar
jseim44 jseim44 is offline
jseim44 is gaining momentum as a positive member of FTE.jseim44 is gaining momentum as a positive member of FTE.
Subscribed!
My brother has an '89 F-250 that's pretty tired and we're thinking about re-working the 351 and modding it a bit but staying with SD and not getting crazy in the $$$$ department.
-Jake
Old 07-30-2013, 05:34 PM
Conanski's Avatar
That looks like a good list of parts, be sure to use all the assembly lube supplied with the cam and lifters, follow the breakin procedure to the letter, and use an oil with a zink additive in the engine from now on.
Old 07-30-2013, 07:42 PM
Well so far upon disassembly ive broken the distributor. While attempting to spin it by the hex on the shaft, the body broke clean in two. Now the base of the distributor is stuck in the block.
Old 07-30-2013, 09:03 PM
Is this the correct intake? The ports seem pretty small.
Old 07-31-2013, 10:03 AM
Conanski's Avatar
Yes that's the correct intake and yes the ports are pretty small, to add to the confusion the 5.0 version of this intake has larger rectangular ports but you can't swap it on because the 5.8 block is wider so the lower portion won't bolt on.
Old 07-31-2013, 07:32 PM
Those small ports are lame. That Edelbrock intake is starting to look good... Its only money.
Got the distributor out today with a couple hits of the slide hammer
Popped the lower intake off today too, the motor is VERY clean inside. Looks like its had its share of oil changes. Very happy with that, plus it only has 80K on the clock. Only problem was I brought home the GM style fuel line disconnect tools instead of the Ford style. Oh well, tomorrows another day. Good news though, Parts showed up today. I'm just waiting on the heads.
Heres whats left of the distributor:
Parts all except exhaust that's laying in the garage:
No stranger to HP/TQ or hydraulic flat tappets.
383 SBC, Holley HP fuel injection.. a large list of other things
Old 07-31-2013, 10:57 PM
0ldman 0ldman is offline
0ldman is starting off with a positive reputation.
Nice.
Btw, the dizzy pic is photographic evidence of vehicular manslaughter.
Old 08-01-2013, 08:32 PM
Pulled the passenger head today. Wish I took a picture, the cylinders have beautiful cross hatch. Getting excited.
Old 08-04-2013, 10:48 AM
More new parts on their way.
Ordered New Oxygen Sensor, Coolant temp sensors, Oil pressure sensor, TPS, Thermostat, Radiator cap, some more gaskets, EGR line from headers to valve, and new connectors for the alternator, and ignition coil.
Still left on the list is Crane rockers and MSD Coil.
Also, I'm on the fence on the Edelbrock intake manifold.
Old 08-04-2013, 11:40 AM
Conanski's Avatar
The Pro Products Typhoon is a copy of the Edelbrock Performer(the single TB car version.. whatever you do don't buy the bigger dual TB truck version it'll choke the motor). The exterior finish of the Typhoon is not as clean as the Edelbrock product but it's close to half the price and exterior finish makes no difference to performance. Here is my 5.8 Typhoon next to the stock lower..
And the complete intake, I cleaned up some casting flange and had it powdercoated crinkle black, overall I think it came out pretty good.
460 Efi Cam ncovelli 1987 - 1996 F150 & Larger F-Series Trucks 4 04-16-2016 11:25 PM
1992 Bronco 351 5.8L BroncoMel 1987 - 1996 F150 & Larger F-Series Trucks 0 10-07-2015 02:30 PM
95 f250 5.8 Help jamiej88 1987 - 1996 F150 & Larger F-Series Trucks 18 08-23-2015 03:22 PM
94 F150 5.8 with blower, cam and exhaust ???? spidermonkey 1987 - 1996 F150 & Larger F-Series Trucks 53 07-20-2008 09:20 PM
Comp Cams Speed Density cam. Trail Rider II 1987 - 1996 F150 & Larger F-Series Trucks 9 08-08-2003 12:54 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
