Misfire at idle
What are you using to take the video? most newer smartphones typically have noise reduction software built in. You may need to turn that off to get the sound you are looking to show.
Tom, this was taken off another website which talked about shudder and misfires.
Mode 6 – Find Ford Misfires Before Code Sets
Mode $06 misfire information displayed
Misfires particularly in Ford cars and trucks can many times be identified before a misfire code sets and turns the CEL (Check Engine Light) on. This is a huge time saver, especially when there is a definite misfire felt but the code seems to take forever to appear. Fords take a long time in some cases to run through it’s necessary drive cycles needed for self testing. Auto technicians deal with this common problem of diagnosing misfires on Ford vehicles with no codes set by using Mode $06. Usually only manufacturer specific scan tools will display misfire data when there’s no code, but OBD 2 generic scan tools that can access mode 6 on Ford vehicles can be a great help.
A misfire that hasn’t set a code or even a pending code, could be caused from a fouled spark plug, spark plug wires, ignition coil, injector or some other culprit. The particular cylinder can be pinpointed with the use of mode $06 diagnostics...
They also talked about how lots of owners had spark plugs that were not all gapped correctly. The correct gap should be 0.32. Maybe that would be a good place to start? They also cleared the Misfire Neutral Profile at the dealer.
Here is the thread that talks about it.
http://www.f150forum.com/f38/2011-55...-fixes-128636/
Warning: The thread is OVER 270 pages long!
I know what you're talking about, but unfortunately the audio is lousy on that video and you can't hear it. Not sure what happened with the audio on that one, but I will try and get a better one tomorrow morning.
It is definitely misfiring; my wife started the truck on that first clip and commented on how much the truck shook.
Understand, I am a little bias with my comment because of all the issues I have had with my truck.
Mine does the same thing on start ups. However, mine blows black smoke prior to the white smoke. Mine did not do this until the delay and the attempted fix at the limp-mode issue. Which the TSB did not fix with my truck. I have been through 2 new catalytic converters, a driver side turbo that locked up, and a whole host of other issues.
My lawyer had me take my truck to an expert "witness" and here is one of the things he found. There are 3 MAP sensors on the intake. The one closet to the engine on the drivers side was coated with oil. Sensors like that are not supposed to have oil on them at all. The other 2 were fine. There were 2 other tubes that should have been oil free, but they were coated with oil as well. He took the throttle body off and was amazed at how dirty it was. He said he would expect a truck with 100,000 miles on it to be that dirty, but not one with 20k.
He cleaned the sensor, the tubes, and the throttle body and went on a weekend test run trying to get it to do the limp mode issue again, about 100 miles. Brought it back and took it apart again. Sensor and tubes were oiled up again and the throttle body was sooting up again. The drivers side cat is also starting break down again.
This guy builds engines with turbos for a living and is doing quite well. He seems to know his stuff. He told me the white smoke is not that big of a deal, however, the black smoke is. He thinks it is because of the oil coated sensor. I would have your dealer check that sensor. However, the only fix for it is aftermarket putting a catch can on the hose.
Good luck with your issue.
Any solutions to this? My 2013 Lariat is going to Ford dealer today due to stumble, miss and black smoke. Also the rotors are warped, something is loose in the steering, myFordTouch is glitchy, drivers door shakes, idler pulley squeaks when cold.... At 13,000 miles! Dropped it off in June and dealer did absolutely nothing after keeping the truck a week. Hope my 4th f-150 isn't my last, but this is disturbing. Please let me know if there is a fix. Thanks!
PM your info to me so I can look into this. I'll need your name, phone number, VIN, mileage, and servicing dealership to get started.
Crystal
#29
I wouldn't let this bother you. To be honest it doesn't really bother me. My only rational concern is that this few seconds of misfiring every day will add up to a screwed up catalytic converter at some point. But other then 5-10 seconds each day my truck runs great!
#30
