Need guidence with codes
#31
checking resistance as in test 1, you are measuring across the injector itself. If you get a reading of zero, you either have the meter not set up, or the plugs on the head (the pigtails ) unplugged. you should be reading around 2.9 ohm. the other possibility would be all harnesses bad, which is unlikely. Test 2 and 3 need to come up open(no reading), as you are measuring for a short. but since test one came out all zero, 2 and 3 are in question.
please double check if you can. If you have a reading in test 2 or 3, check your harnesses under the valvecover. if you not reading anything on one of the connections for the injectors, you also need to investigate further for wiring damage.
If the test comes out good, suspect the IDM bad.
hope that helps.
if you need to , pm me and i can talk you through on the phone sometime this afternoon
hope that helps.
#32
#33
Well the new IDM is installed.
I still have a CEL, I cleared my codes too I have only driven about half a mile.
Everything seems to be back to normal the truck is idling normal again. Its defiantly drivable, just something doesn't sound right Im probably being a worry *****. Im going to replace rear hub seals and take her for a good 25 mile drive. I hope the CEL clears it self.
maybe some air in the system??
#34
#37
cutlass
13
03-11-2024 11:59 AM
bkuuz1
12-03-2013 03:33 PM
ZeroAccess
09-15-2008 04:07 PM
