****1994 Ford F150 Bucking and Jerking*** - Ford Truck Enthusiasts Forums
Old 07-28-2013, 03:38 PM
Eric Shaw Eric Shaw is offline
Eric Shaw is starting off with a positive reputation.
I need urgent help have no idea what the problem is. I have a 1994 F150 5.0 4x4 E40D tranny with 235,000 miles and a three year old rebuilt transmission. I recently had the fuel injectors cleaned and also replaced the the throttle position sensor. My problem is the truck jerks and bucks at any speed when I put it into reverse or drive it like slams into the gear it is also ideling real high and has almost no power going up hills sometimes it will not get passed 20 to sometimes 40 mph if i can even have the peddle to the floor and it takes forever. Please help what could this be I am out of ideas.
Old 07-28-2013, 04:21 PM
kermmydog's Avatar
kermmydog kermmydog is offline
kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.
Do you have any codes? Why did you replace the TPS? Checking codes is your first job.
Craig
Old 07-28-2013, 07:35 PM
No codes, recently fixed and egr problem, replaced the throttle position censor was suggested by a friend that could be the problem it is not.
Old 07-28-2013, 08:11 PM
f-150_1993's Avatar
f-150_1993 f-150_1993 is offline
f-150_1993 is starting off with a positive reputation.
LOL you might want to check your ignition coil go test it at the auto parts, they should do it for free. To me it sounds like you got some really weak spark and the bucking might be the motor misfiring. Keep in mind that an unloaded coil vs a loaded coil (in gear) will behave differently if it is on it's way out!
Old 07-28-2013, 10:54 PM
slrgreg slrgreg is offline
slrgreg is starting off with a positive reputation.
Quote:
Have you checked your fuel system for good pressure, fuel pump, clogged
fuel filter, my truck was acting like yours and it was a clogged filter.
04 f150 5.4 bucks/jerks under slight acceleration joshinthe586 2004 - 2008 F150 28 04-19-2016 06:21 PM
2006 F150 Jerks/Bogs When Transmission Shifts LiquidSpecialties Clutch, Transmission, Differential, Axle & Transfer Case 0 12-20-2014 01:09 AM
braking problem blueford1975 1973 - 1979 F-100 & Larger F-Series Trucks 1 12-19-2014 11:32 PM
1994 F 150 Auto Trans Jerking Low Speed Roytonk 1987 - 1996 F150 & Larger F-Series Trucks 2 06-25-2014 02:42 PM
05 f150 "jerking" in overdrive Joco4x4 2004 - 2008 F150 9 02-27-2013 09:49 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
