Sometime no reverse
Sometime no reverse
I have a 2003 automatic 6.0 and some times when I put the truck in reverse in wont engage. I can just sit there and rev it up and it won't move. You have to put it in drive then back to reverse for it to work usually works as soon as you do that. Every once in a blue moon you have to do that multiple time for it goes in reverse.
It could be several things. It could be a bad seal in the reverse clutch, a sticky solenoid, or a loose shift lever.
When moving the shift lever is it firm and easy to find each gear? Or is it sloppy? If it is sloppy you need to lay under the dash on the driver's side. Look up the steering column. There are two Torx head screws that hold the shift tube to the column. If they are loose or missing that will cause this.
If it is a stick solenoid new fluid will sometimes fix it. A bad clutch seal requires the trans to come out to be fixed.
I am having this same issue. A buddy of mine that owns a transmission shop said what everyone else has. Flush and fluid exchange with new filters. If that doesn't work and no codes, it is more than likely sticking pressure/clutch plates(that is what he called them) in the reverse drum. He also said it could be a busted snap ring in the drum causing issues.
I hope it is just a fluid and filter issue, I just gave him 1800 to rebuild the transmission in my car.
Maybe Ohming out the Silinoids will be an Option for you
Shift Solenoid PCA Gear 1 1 0.9 - 1.3 4.1 - 4.7 W
Shift Solenoid PCB Gear 2 2 0.9 - 1.3 4.1 - 4.7 W
Shift Solenoid PCC Gear 3 3 0.9 - 1.3 4.1 - 4.7 W
Shift Solenoid PCD Gear 4 4 0.9 - 1.3 4.1 - 4.7 W
TCC Solenoid Gear 5 5 0.9 - 1.3 4.1 - 4.7 W
Shift Solenoid PCE Gear 6 6 0.9 - 1.3 4.1 - 4.7 W
EPC Solenoid Gear 7 7 0 - (0.8 - 1.2)
Duty MIN - MAX
5.1 - 5.8 W
Case Connector Pin
Number
[***************][***************][***************]TranX 2000
Harness Wire
[/COLOR]
[/COLOR]
[/COLOR]Vehicle Function [***************][***************][***************]TranX 2000[/COLOR][/COLOR][/COLOR]
Output Location
[/COLOR]
[/COLOR]
[/COLOR]TranX 2000
25 Way Pin
1 [***************][***************][***************]Brown [/COLOR][/COLOR][/COLOR]Shift Solenoid PCE [***************][***************][***************]Channel 6 [/COLOR][/COLOR][/COLOR]4
3 [***************][***************][***************]Dark Green [/COLOR][/COLOR][/COLOR]Shift Solenoid PCB [***************][***************][***************]Channel 2 [/COLOR][/COLOR][/COLOR]8
4 [***************][***************][***************]Red/Green [/COLOR][/COLOR][/COLOR]Shift Solenoid PCD [***************][***************][***************]Channel 4 [/COLOR][/COLOR][/COLOR]6
5 [***************][***************][***************]Pink [/COLOR][/COLOR][/COLOR]Shift Solenoid PCC [***************][***************][***************]Channel 3 [/COLOR][/COLOR][/COLOR]5
7 [***************][***************][***************]Red [/COLOR][/COLOR][/COLOR]+12V to PCA & TCC 12
8 [***************][***************][***************]Purple [/COLOR][/COLOR][/COLOR]TCC Solenoid [***************][***************][***************]Channel 5 [/COLOR][/COLOR][/COLOR]3
9 [***************][***************][***************]Green/White [/COLOR][/COLOR][/COLOR]Pressure Switch C [***************][***************][***************]Sensor 3 Test Point [/COLOR][/COLOR][/COLOR]17
10 [***************][***************][***************]Yellow [/COLOR][/COLOR][/COLOR]EPC Solenoid [***************][***************][***************]Channel 7 [/COLOR][/COLOR][/COLOR]1
11 [***************][***************][***************]Yellow/Red [/COLOR][/COLOR][/COLOR]Pressure Switch D [***************][***************][***************]Sensor 4 Test Point [/COLOR][/COLOR][/COLOR]18
12 [***************][***************][***************]Blue [/COLOR][/COLOR][/COLOR]Shift Solenoid PCA [***************][***************][***************]Channel 1 [/COLOR][/COLOR][/COLOR]7
13 [***************][***************][***************]White/Red [/COLOR][/COLOR][/COLOR]Pressure Switch E [***************][***************][***************]Sensor 6 Test Point [/COLOR][/COLOR][/COLOR]20
14 [***************][***************][***************]Orange [/COLOR][/COLOR][/COLOR]Pressure Switch A [***************][***************][***************]Sensor 1 Test Point [/COLOR][/COLOR][/COLOR]15
15 [***************][***************][***************]White/Purple [/COLOR][/COLOR][/COLOR]Trans Range Park Sensor [***************][***************][***************]Sensor 7 Test Point [/COLOR][/COLOR][/COLOR]21
16 [***************][***************][***************]White [/COLOR][/COLOR][/COLOR]Pressure Switch B [***************][***************][***************]Sensor 2 Test Point [/COLOR][/COLOR][/COLOR]16
17 [***************][***************][***************]White/Green [/COLOR][/COLOR][/COLOR]Trans Range Park Sensor
Return
18 [***************][***************][***************]Red/Blue [/COLOR][/COLOR][/COLOR]TOT Sensor [***************][***************][***************]Sensor 5 Test Point [/COLOR][/COLOR][/COLOR]19
20 [***************][***************][***************]Red [/COLOR][/COLOR][/COLOR]+12V to PCA and PCB 12
21 [***************][***************][***************]Red/Brown [/COLOR][/COLOR][/COLOR]Power to Trans Range
Park Sensor
[***************][***************][***************][/COLOR][/COLOR][/COLOR][***************][***************][***************][/COLOR][/COLOR][/COLOR][***************][***************][***************]Sensor 8 Test Point [/COLOR][/COLOR][/COLOR]22
22 [***************][***************][***************]Red/Black [/COLOR][/COLOR][/COLOR]GND for Pressure
Switches and TOT
24 [***************][***************][***************]Red/Brown [/COLOR][/COLOR][/COLOR]+12V for PCC, PCD, PCE 13
CONNECTOR:
(Looking into harness connector)
TranX
Duty MIN - MAX
5.1 - 5.8 W
Case Connector Pin
Number
Harness Wire
[/COLOR]
[/COLOR]
Output Location
[/COLOR]
[/COLOR]
[/COLOR]TranX 2000
25 Way Pin
Return
Park Sensor
Switches and TOT
CONNECTOR:
TranX
