Fuel pump or Vapor lock?????? - Ford Truck Enthusiasts Forums
Old 07-28-2013, 10:39 AM
retro48/52's Avatar
retro48/52 retro48/52 is offline
retro48/52 is starting off with a positive reputation.
Hello, I have a 429 cid in a 52 F1 and having trouble I can't understand. After about 20 minutes of driving, the engine seems to get hotter than normal then the engine stops. I thought it could be vapor lock cause the temp on my temp gauge goes to 220 and when I stepped on the gas to climb a hill, that is when the engine gasps for fuel and stops. But, I open the hood and look at my fuel pressure gauge which is in the fuel line, it reads ZERO pressure. The fuel pressure gauge is mounted to the firewall above the steering column. Normally it reads 5-6 pounds in the garage. Can someone tell me if vapor lock would make the fuel pressure gauge shows ZERO, or does that mean I have no pressure from my electric fuel pump residing in the back mounted to the frame? After the engine cools down for 3-5 minutes I can start the engine and if I don't floor the gas pedal, at least get it home to scratch my head again and ask this forum for help. My fuel line from the carb to the fuel pressure gauge is already insulated from heat, (I think, at least it is covered with 2000 deg. insulation) . <!-- / message -->
<!-- sig --> __________________
Old 07-29-2013, 06:25 AM
mrford49 mrford49 is offline
mrford49 is starting off with a positive reputation.
Normaly you have that problem with a stock type mechanical fuel pump. Install a return fuel line on your truck much smaller than your fuel line as it will cool your fuel down a lot. 1/8'' copper line will work just fine but make sure you have enough fuel pressure and volume. Sometimes you may have to restrict the fuels return. They sell fuel filters with a return port already on them try one of those first before custom making one. Mopar's had them as well as other makers. Cooling the fuel up to the carb will help you big time. Been there done that!
Old 07-29-2013, 10:33 AM
retro48/52's Avatar
Thanks for the response. I sure will try that.
Vapor lock question... Tyler S 1948 - 1956 F1, F100 & Larger F-Series Trucks 12 06-23-2015 11:54 PM
'67 F600 Fuel Starvation Problem...I think dbreienrk1 Large Truck 18 08-06-2014 09:41 PM
Vapor lock and fuel pressure gauge retro48/52 1948 - 1956 F1, F100 & Larger F-Series Trucks 10 07-30-2013 10:58 PM
Vapor Lock? B Todd 1948 - 1956 F1, F100 & Larger F-Series Trucks 29 06-11-2013 06:54 PM
87 F150 Hi MPG mark s 1987 - 1996 F150 & Larger F-Series Trucks 32 03-11-2001 01:32 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
