2.5 inch coil spacers & 2.5 inch lift blocks - Ford Truck Enthusiasts Forums
Old 07-28-2013, 10:35 AM
f-150_1993's Avatar
f-150_1993 f-150_1993 is offline
f-150_1993 is starting off with a positive reputation.
Ok I have a 1993 F-150 XLT extended cab 2WD that I am gonna lift just a tad. I just want information on what else I will need to complete the job. The kit is the following...
I already have adjustable camber bushings so that's already out of the question as something I will need. The extended U bolts are included in the kit but I think I will be needing something else for the front end. I keep hearing that the bolt that goes through the I-beam (2WD) will not be long enough after the spacer is put in place? Is this true? What extra items have you all utilized for a lift like this on a 2WD truck... thanks! And please don't criticize on me being cheap and not getting lift coils instead just please don't...
Old 07-28-2013, 11:05 AM
Bob Gervais's Avatar
Bob Gervais Bob Gervais is offline
Bob Gervais has a great reputation on FTE.Bob Gervais has a great reputation on FTE.Bob Gervais has a great reputation on FTE.Bob Gervais has a great reputation on FTE.Bob Gervais has a great reputation on FTE.
The bottom spring retainer cup stud may be too short with spacers installed. You can buy extenders for those on Ebay also, and I know Jeff's Bronco Graveyard has them too.
For the front, with a 2.5" lift, camber bushings may not be enough to get everything back in spec. You may want to check into drop brackets for the I beams and radius arms.
Old 07-28-2013, 11:41 AM
f-150_1993's Avatar
What do those stud extenders look like? please show me And you are correct about the height affecting camber too much and making it out of spec but I got springs that are sagging already so if you take that into account let's just say the actual lift amount will be hmm less than 2 inches because of the aged springs... or maybe close to 2 inches hopefully lol
Old 07-28-2013, 11:52 AM
f-150_1993's Avatar
wait aren't the stud extenders on the kit for that? sorry it's kind of new to me... IDK if you actually looked at the link to ebay, but just correct me if i'm wrong
Old 07-28-2013, 11:56 AM
I did look at the link before replying. In the kit, the extenders LOOK exactly like coil spring stud extenders, but they describe them as shock extenders, which are totally different.
Here's a link to the extenders on another site. They're listed for a 4wd, so you'd probably have to call them and see if they'll fit a 2wd also.
Ford 5/8" Stud Extenders (1Pair) 4WD 1980-1997
Old 07-28-2013, 12:14 PM
f-150_1993's Avatar
Just found out that 2WD trucks use a 3/4 extender while 4WD use 5/8, here is the link to the 2WD version on the same site you gave me... 81-96 Ford F150 / Bronco / Ranger Daystar 2" Leveling Kit KF09108BK
Maybe they are mislabeled they look exactly the same to me, I messaged the seller days back but never responded to my question stupid seller! Anyone else had experience with these "Ebay" kits?
Oops sorry this is the correct link... http://4x4.fatbobsgarage.com/ford-br...px?Thread=True
Old 07-28-2013, 12:21 PM
f-150_1993's Avatar
Just re-read the fitment application list and it's not even for a 2WD F150 LOL it's only for a ranger and bronco II
Old 07-28-2013, 06:25 PM
Well, if the kit doesn't come with them, they're easy enough to make. Figure out the thread size, then get some threaded rod and coupling nuts in the same size at your local hardware store. Cut threaded rod pieces to the length you need, and screw them onto the factory studs using the coupling nuts.
Old 07-28-2013, 07:27 PM
f-150_1993's Avatar
Ahh I see, yes I heard about the local hardware store having those things to make my own extended studs, well thank you for your help, I guess I will order then when I get it will ask around if indeed the included "extended stud" is the extended stud needed and not some shock extender lol
Old 07-28-2013, 11:16 PM
f-150_1993's Avatar
Is this how it's supposed to look stock? It's a 2WD and the pictures i've been seeing look different, can anyone confirm please if where the spring sits looks like this...
Old 07-29-2013, 12:22 AM
Big_Zach Big_Zach is offline
Big_Zach is starting off with a positive reputation.
Coil Spring above looks the same as mine, in a 90 F150 2wd. And I'm kinda sure the suspension didn't change between those years, seeing as lift kits fit up and down the scale.
Old 07-29-2013, 12:29 AM
Also, have you thought about Bronco Graveyard? Forgive my shameless advertising, but he has 3" rear blocks tapered to address drive shaft angle, for $69, then what you need is 3" front spacers or his 4" front coils for $135 and it'll level you out. I understand balling on a budget, and wanting to save where you can, but suspension is everything, without where would we be. And Bronco Graveyard is really well known, compared to some ebay seller.
Old 07-29-2013, 12:47 AM
f-150_1993's Avatar
I don't need that high lol, I am already pushing it with 2.5", need it so ppl can get on without jumping. anyways the spacers will be on top of that cup thingy right? and just below the spring? in other words in between lol
Old 07-29-2013, 01:12 AM
I've never done it, but I'm guessing it goes under the coil, on top of the coil bucket(cup thingy). Other than that it can only go under the coil bucket. You usually have to take off the wheel, shock, coil spring, and coil bucket, install the spacer, then put it all back together.
Leveling Kit on '89 F-250 2WD ??????? CrispyWafer Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 6 12-17-2015 07:09 PM
2wd or 4wd lift kit? jason832 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 6 07-25-2014 02:20 PM
Which leveling kit is better? joegeds 1987 - 1996 F150 & Larger F-Series Trucks 0 09-03-2013 11:04 AM
Whats in this Lift kit??? Shwan_89HD 1987 - 1996 F150 & Larger F-Series Trucks 12 06-07-2013 05:54 PM
Leveling /Lift Options & Tire Size Questions RollTideRoll 1999 to 2016 Super Duty 7 12-31-2011 06:30 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
