Considering a Red Head steering gear - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 07-27-2013, 06:23 PM
catzr440 catzr440 is offline
catzr440 is starting off with a positive reputation.
so I'm thinking i need to get one of these "red head" steering boxes, my truck has a very bad wonder! And seems to be extremely bad at low speeds some times!! Almost like it wants to pull ya off the road! I just had all new ball joints, and all new tie rods installed yesturday, and still pulls and wonders VERY BAD!!
Old 07-27-2013, 08:37 PM
Tom's Avatar
Tom Tom is offline
Tom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputation
Hi catzr440,
I split your post off into its own thread, you bumped a 3-year-old thread that was about a different issue. It sounds to me like your first stop need to be for an alignment. Pulling and wandering are both typically alignment issues, and if you installed new tie rods without an alignment you may well have made the issue worse.
I really liked the improvement the Red Head steering gear gave my Excursion, but you should track down your issue first before spending the money on one. Pretty confident you have an alignment issue.
Old 07-27-2013, 09:42 PM
thanx for the tip!!! I took some good advice from a friend and made an adjustment on the steering box, it seems to not wonder, and much better steering response!! But yeah, Monday I will call for an alignment! Thanx!!
Old 07-27-2013, 11:11 PM
splice1985 splice1985 is offline
splice1985 is starting off with a positive reputation.
Mine had fairly terrible wander when I first got it. The adjustment screw for the gearbox was as tight as it would go, so replaced the gearbox. The best deal I found was on a Motorcraft Gearbox from Rockauto.com. I've been happy with that. Replacement at the local auto hobby shop took me about 3 hours. The steering tightened up a bit with mine, but didn't go all the way away until I replaced all the front end bushings, springs, shocks, and got an alignment. Rides smooth and tracks straight now.
Old 07-28-2013, 09:13 AM
bdman74 bdman74 is offline
bdman74 is starting off with a positive reputation.
Anybody know what those run dollar wise? I've had my mechanic going over my new to me truck and he tells me most of my play is in the box. I'll have a better assessment myself after alignment and new tires, but boy coming down hwy 75 home with it was lil hairy.
Old 07-28-2013, 09:31 AM
Quote:
I'm tellin ya, I'm having the same issue!! Trying to keep it in my lane going 70!! I dropped it back to 60, to try n be a lil safer! I should mention that my truck had the pulling and wondering BEFORE I had the front end worked on, but Monday hopefully I can get the alignment done!
Old 07-28-2013, 11:06 AM
1954oldred 1954oldred is offline
1954oldred is starting off with a positive reputation.
Mine was doing the same as you all...aligned front end all components good. Adjusted nut on top of stock box, it helped, for a while.
Last week bought and installed red head box...truck is soooooo much better! No more issues.
I paid $355.00 for mine.
Old 07-28-2013, 03:49 PM
PSDlongbox's Avatar
PSDlongbox PSDlongbox is offline
PSDlongbox is gaining momentum as a positive member of FTE.PSDlongbox is gaining momentum as a positive member of FTE.
once it gets all slopped out, tightening the adjuster is a temporary fix. I put in a red head box a few months ago and wouldn't ever own another truck without one.
Old 07-31-2013, 03:06 AM
well after getting an alignment done on my truck, it still has the same problem!! I just ordered the red head box, I have the 36 spline gear box. It runs 336.00 with a 200.00 core charge, I hope its worth every penny!
Old 07-31-2013, 05:04 AM
I just had an alignment done!!
Old 07-31-2013, 08:51 AM
I don't have my truck back yet but I did stop by the shop and got a test drive in on the new brakes yesterday. They were ate up with problems, had to replace all pads, 3 rotors, and two calipers due to seized up slider pins. He said not a single steering joint had any grease so he greased everything good and adjusted the worm gear on the stock box a hair. It drove like a totally different truck, like new almost. Still haven't even gotten the alignment and tires, that should help more as well, unfortunately the E Brake wasn't working so that's still being addressed and I like you think it's just a matter of time before I have to change that steering box. Tightening that worm gear really is just putting a band aid on a worn out box.
Old 08-02-2013, 10:26 PM
well I just got back from a good long test run, highway and 2 tracks...........this redhead box is worth its weight in gold!!! Not even as much of an inch of wandering, no more sloppy wheel play, no tugging to one side of the road or the other!!!! Let me say this.....them boys know how to rework a gear box!!! Very VERY impressed!!!!
Old 08-02-2013, 11:03 PM
the_auto_tech's Avatar
the_auto_tech the_auto_tech is offline
the_auto_tech has a good reputation on FTE.the_auto_tech has a good reputation on FTE.the_auto_tech has a good reputation on FTE.
Sounds like I need one of these.
Old 08-02-2013, 11:08 PM
I would highly recommend one, I'm not sure on everyone elses front end issues, but in my case that was the problem from the start! Guess it didn't hurt any by having my front end all rebuilt! Just my wallet! But well worth the money in my book!
Old 08-03-2013, 02:07 PM
Misky6.0's Avatar
Misky6.0 Misky6.0 is offline
Misky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputation
X2. The redhead worked wonders on my '05 excursion too. Also front tire wear and pressure makes a big difference too. Be sure you rotate your tires with each oil change.
Red Head Steering gear box installed Monster-4 1999 to 2016 Super Duty 406 02-06-2017 07:26 AM
Steering Damper 77_f250_custom 1973 - 1979 F-100 & Larger F-Series Trucks 6 04-21-2015 08:17 PM
1978 F100 steering gear replacement center. PancakeF150 1973 - 1979 F-100 & Larger F-Series Trucks 6 07-18-2014 11:12 AM
I think I will be replacing the steering box... Joco 1967 - 1972 F-100 & Larger F-Series Trucks 10 06-13-2014 03:04 PM
Remanufactured Steering box readhead or MotorCraft ? X1Lightning 1999 to 2016 Super Duty 7 05-13-2013 10:18 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
