engine tips
engine tips
y I have a question or two. Thursday I was returning home and I sprung an oil leak from the oil dipstick tube adapter on the pan and either through the valve cover or the valve cover gasket. What was crazy, I had just looked at the oil pressure just as this happened - my truck had bellowing smoke from under the truck and hood and huge amounts of black smoke out of the pipe. My truck now runs like total crap.
Once I return home next week, I need to do a compression check. From there, where should i focus on to see if the engine is toast or if I can fix it? also, if I recall, the valve covers are hard plastic. Is there a manufacturer that makes metal valve covers for these engines that are affordable? Additionally, we are some suggestions to do to this engine if i have to rebuild? In other words, can the block be bored larger and have increased compression...stuff like that. I want to get more power out of this engine.
Thank you for your consideration here.
drpaul311
drpaul311
At this point I am only speculating the disaster! I haven't done the comp check or checked to see if there is a bent pushrod or nothing. As for the VCs, there is a manufacturer that makes aluminum but they are $750. That is ridiculous if you ask me! I want to get rid of the hard plastic for metal but I don't want to pay a bazillion dollars doing it. Just thinking, gas engines, one could also install a
Cam with more lift...does that apply with these diesels?
No dents in the pan. What sucks I recently recently replaced that oil pan adapter and went through that whole hassle. It stopped leaking until the other day. No thrown rod. Starting runnin bad so I shut it down.
I am aware of having insufficient oil and running poorly. I learned that the hard way. That is why when it started running bad, I checked the oil pressure. The leak is from the oil dipstick adapter and the valve cover or hte valve cover gasket. Additionally, as the truck idles, oil is puddling on top of the passenger valve cover. That is why I think the VC is hard plastic that has a crack.
I think I'm wrong on the vc's, they seem like plastic, but I think Aaron and Gabe are right. Heck, I just cleaned mine up and painted them, I should have known..
DIesel motor is a lot different than gas. IIRC, these are already like 17:1 compression. Lots different buiding a gas motor than a diesel. You can get a different cam, but then again, there is a lot more to be done before you'd even need a cam upgrade. You dont even need to touch the inner parts of the motor and you can get pretty reliable 500+hp out of these. But, your checkbook better be ready. It costs a lot to make big hp out of any motor, gas or diesel.
shane sorrells
10-01-2012 09:39 AM
chamblizi
09-10-2012 03:41 PM
