HELP! Been trying to fix Power Steering Lines For 2 Weeks! Parts Won't Fit!
Old 07-27-2013, 05:29 PM
ArlyDude's Avatar
ArlyDude
ArlyDude is offline
I have a 97 F-350 w/ the 7.5 Engine.
I have a huge leak in the power steering lines so I replaced them both. I ordered them from Advance Auto and installed them. On both of the lines, the connector that screws into the pump itself there was an attachment on the end to make a tight fitment (where the 0 Ring would go).
The lines I got do not have anywhere to put an O-Ring and there is play on the Pressure side line when i just screw it in. On top of that, there is a piece that seems to be missing. I have included a picture of the old piece. As you can see there is a metal piece attached to the end of the screw in part that made for a better fitting inside the pump when screwed in, and that does not exist on my lines and I cannot even find that as an option on advance auto's computer system at their store. the line I got is def the correct hose and tube assembly, but I just need the small metal piece at fits into the end? Can anyone speak from experience what is going on here and what I have to do to fix it? Thanks!
Old 07-30-2013, 11:00 AM
mudslinger02's Avatar
mudslinger02
mudslinger02 is offline
Do you have hydroboost or not? It makes a difference on which hose you need. Also, you need to know the build date of your truck. To me, that almost looks like it could be Gates part number 356540
kevincw
2004 - 2008 F150
12-30-2015 12:13 PM
mario9272
02-04-2014 04:16 PM
ArlyDude
1999 to 2016 Super Duty
07-27-2013 09:37 PM
safari1957
01-07-2012 09:01 AM
Quick Reply: HELP! Been trying to fix Power Steering Lines For 2 Weeks! Parts Won't Fit!
