No Signals on my 1972 F-100 - Ford Truck Enthusiasts Forums
Old 07-27-2013, 01:31 PM
camcol19 camcol19 is offline
camcol19 is starting off with a positive reputation.
I recently had my dash apart replacing the dashboard and turn signal switch now I have no turn/brake lights but my horn still works where do I start?
Old 07-30-2013, 11:46 PM
go-part go-part is offline
Former Vendor
go-part is starting off with a positive reputation.
Old 08-22-2013, 05:17 PM
BV 1980 F100's Avatar
BV 1980 F100 BV 1980 F100 is offline
BV 1980 F100 is starting off with a positive reputation.
First start by checking your fuses. I Know that your turn signal indicator switch is located underneath the steering wheel so u will have to remove it to check it and make sure it is still operating properly
Horn and turn signals not working. elymashburn 1997 - 2003 F150 0 09-23-2015 05:32 PM
Turn signal Switch NickOlsen53 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 11 04-03-2014 06:50 PM
turn signal blues Killgore 1973 - 1979 F-100 & Larger F-Series Trucks 15 01-14-2014 05:25 PM
mirror turn signals Deebo 2004 - 2008 F150 0 12-17-2013 06:53 AM
turn signal lock and cancel cliebold 1987 - 1996 F150 & Larger F-Series Trucks 8 07-24-2002 05:25 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
