P-Metric or LT?
P-Metric or LT?
So, it appears I'm going to be replacing my stock tires on the F150 a little sooner than anticipated as I noticed some unusual sidewall deformations the other day while detailing. Anyways, truck came with LT235/75/r17 Load E tires and the 7200# suspension. I'm considering switching to a 265/70r17 tire and notice a huge price difference between the P-metric tires and the LT tires. Doubt this truck will see much towing, though the occasional firewood and boat launch trip is likely but its mostly a highway commuter with occasion two track use.
Seems like both the D and E range LT tires sport an additional body ply compared to the P-metric tires as well as roughly 1000lbs high weight rating (so about 2000lbs per axle I guess). While I'm sure it would be safe enough to run the p-metrics would I be sacrificing anything in handling or durability? The last thing I want is to pick up a flat on a fire trail because I saved $300 on p-metric tires...
Kinda shocked Derrick from The Tire Rack hasn't yet chimed in here.........
Cheaper ain't better especially when you're talking about tires! The LT's were factory-installed for good reason. The few hundred dollars you might save one time could be wiped out immediately with a failed tire that causes an accident.
Despite your anticipation of limited or no real loading conditions its probably the occasional use with P-rated tires that would be the real problem.
FWIW I'm running a set of Michelin LTX's on my E250 since '08, 62K miles with no less than 40% of original tread left. Paid about $800 for the set, trouble free since then so not a bad investment IMHO.
Stay safe---it ain't worth it to do otherwise!
elemirand
10-04-2004 10:23 AM
