Towing 14K with 6.2 - Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8
Towing 14K with 6.2
Old 07-27-2013, 12:25 AM
Fireboater's Avatar
Fireboater Fireboater is offline
Fireboater is starting off with a positive reputation.
Towing 14K with 6.2
Hi there, I have a 35ft Toyhauler that Max GVW is 14K, does anyone with the 6.2L tow anything this big, and how does it do. Also what are your mpg,s, I am seriously looking at the 6.2 and with the 4.30's for my tow vehicle, not totally set on the 6.7l. Any comments or advise would be appreciated. I have a 99 F-350 with the 2V V10 with 5 star tune,CAI and Flowmaster 50 mufflerit does OK but could use more power on the hills.
Thanks
John
Old 07-27-2013, 07:58 AM
FordmanNJ's Avatar
FordmanNJ FordmanNJ is offline
FordmanNJ has a great reputation on FTE.FordmanNJ has a great reputation on FTE.FordmanNJ has a great reputation on FTE.FordmanNJ has a great reputation on FTE.
That is alot of weight to be towing. Diesel will be the better bet in this case. Check out your local DMV laws when it comes to registration and or operation of the vehicle. Take a look at the towing guides, then take it from there.
Towing Guides | fleet.ford.com
Good Luck with your research.
Old 07-27-2013, 08:07 AM
rvpuller's Avatar
rvpuller rvpuller is online now
rvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud of
This is what I'm pulling http://www.ford-trucks.com/forums/12...his-thing.html, the 6.2 may not be for everyone pulling a heavy load but form the F250 with 4.30 gears on up are rated to pull over 14K 5th wheels. I'm also doing it with a DRW so I have 17" wheels over the standard 18" on the SRW so I have a little better final to the pavement gearing. I came form a 2000 F350 DRW 2V V10 that has more HP and torque than your 99 V10 and so far I'm happy with the way it hands my load.
Denny
Old 07-29-2013, 12:26 PM
Mmaxed Mmaxed is offline
Mmaxed is gaining momentum as a positive member of FTE.
I tow a similar toy hauler with a '08 V10. It gets the job done, but if I was pulling more often, I would have a diesel again.
Old 07-30-2013, 10:01 PM
fg250's Avatar
fg250 fg250 is offline
fg250 is starting off with a positive reputation.
I towed somewhere around 14k with my truck last weekend and it did just fine. Now, I didn't go only a few miles taking my tractor on a tri-axle equipment trailer to my hunting property, but there are 4 big hills to climb and it wasn't a problem at all. ( I've got 3.73 gears)
Old 08-01-2013, 05:41 PM
twofifties twofifties is offline
twofifties is starting off with a positive reputation.
14k toy I'd go with the diesel. I haul 14k (fully loaded dump trailer) with my 6.2, and it handles it well, but it's not over distance and doesn't catch near as much wind. If you only do it a couple times a year, maybe the 6.2. Any more, go with the diesel.
Got my eye on a 2011 kameronth 2009 - 2014 F150 3 06-05-2014 11:17 AM
6.2 V8 AZ Gary Modular V8 (4.6L, 5.4L) 3 04-22-2014 02:22 PM
Possibly upgrading to a 6.2 SD from a 6.8 3v v10 FX4Range R 1999 to 2016 Super Duty 2 10-02-2013 09:38 PM
6.2L with 4.30s DCP 1999 to 2016 Super Duty 12 09-25-2013 05:26 PM
Any changes to the 2014 SD or 6.2? Delawhere? 6.2L V8 3 08-15-2013 03:28 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
