50 F1 289/T5 with stock suspension
I have a friend here in Middle TN who is building a 50' F1 as a Father and Son project and has hit some roadblocks. He wants to run a 66' model 289 and a later model Mustang T5. His "builder" cut the cross member he bought that fit his application because he couldn't get the engine and tranny in. My questions are has any built a F1 using a T5 behind a SBF? If so did you use a Mustang sourced T5? The truck is running a stock front suspension. Where did you get your cross member from? I used the search function but only saw things that talked around this particular combo. Thanks for any and all advice.
Frame
Cab Mounted
Frame
Cab Mounted
I can't imagine why the builder couldn't get the engine/tranny into the truck. Might need to use a rear sump oil pan and sump to give axle clearance. and a modified tranny crossmember to support the tranny mount. I really question the builder's competency if this install is a stumbling block, it's about as basic a swap as there is. Mid Fifty offers a cut to fit tubular motor mount for the 289 that should work with the F-1 frame.
I used something like these...
http://www.ebay.com/itm/700R4-4L60E-T56-T5-Universal-Transmission-Crossmember-3-DROP-/380677487583?pt=Motors_Car_Truck_Parts_Accessories&hash=item58a2257bdf&vxp=mtr
http://www.ebay.com/itm/1994-1998-Ford-Mustang-Transmission-Mount-T5-Manual-/390630662383?hash=item5af366e0ef&vxp=mtr
They can be found pretty easily on the interweb.
Cheers Brian
Cheers Brian
700R4 4L60E T56 T5 Universal Transmission Crossmember 3" Drop | eBay
1994 1998 Ford Mustang Transmission Mount T5 Manual | eBay
Cheers Brian
Cheers Brian
I installed a 66 289 and a C4 trans in a '50 back in the 70's when I was a kid. So I know the SBF will fit in place perfectly without any cutting or modifying the frame or floor/firewall, and using the stock front sump oil pan. We made our own side mounts and welded them to the frame, no aftermarket crossmember necessary.
The mount on the C4 lines up perfectly with the original crossmember and all that needs to happen there is to create a pad for the insulator to attach. The T5 is a different issue. The trans itself is larger and longer, so one must get considerably more creative to install the gearbox over the slushbox. There is a thread in here somewhere that showed one guy's custom install where he created a gorgeous extension to the crossmember from scratch to make everything fit like it should. It's definitely some work, but totally do-able.
For a mild 289, he can use a later-model S-10 T5 ('91-on, I think), as they are world class, have the Ford bolt patteren on the trans, and have the desirable shifter. Only thing is, they also have the 4.03 1st gear. Adapting the input shaft may be more trouble than it's worth, too. There are kits everywhere to put a T5 behind a flathead, and I see the stock engine mounts are still there..... Hmmmmm....
The shifter location is the biggest stumbling block. Easiest solution is a set of bucket seats. The tailshaft swap is a simple bolt in, just be sure to use a world class tailshaft assembly with a world class T5 tranny, or a non world class tailshaft assembly with a non world class T5. (do a search on the web to learn the differences and instructions on swapping the tailshafts). It's not a difficult process and within the capabilities of anyone with average mechanical skills and tools.
canadian_diesel1964
34
09-26-2010 08:56 PM
rpol7966
03-06-2009 08:25 PM
DJOHNSTON78
10-13-2008 11:02 PM
52 ford pick-up
02-09-2008 02:49 AM
