Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1948 - 1956 F1, F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
50 F1 289/T5 with stock suspension
Old 07-26-2013, 11:17 AM
tacson's Avatar
tacson tacson is offline
tacson has a very good reputation on FTE.tacson has a very good reputation on FTE.tacson has a very good reputation on FTE.
I have a friend here in Middle TN who is building a 50' F1 as a Father and Son project and has hit some roadblocks. He wants to run a 66' model 289 and a later model Mustang T5. His "builder" cut the cross member he bought that fit his application because he couldn't get the engine and tranny in. My questions are has any built a F1 using a T5 behind a SBF? If so did you use a Mustang sourced T5? The truck is running a stock front suspension. Where did you get your cross member from? I used the search function but only saw things that talked around this particular combo. Thanks for any and all advice.
Frame
Click the image to open in full size.
Cab Mounted
__________________
DONALD
1955 Ford F100 with a 5.0 EFI/AOD
Old 07-26-2013, 12:28 PM
AXracer's Avatar
AXracer AXracer is offline
AXracer is a splendid one to beholdAXracer is a splendid one to beholdAXracer is a splendid one to beholdAXracer is a splendid one to beholdAXracer is a splendid one to beholdAXracer is a splendid one to beholdAXracer is a splendid one to behold
Chuck Frank
I can't imagine why the builder couldn't get the engine/tranny into the truck. Might need to use a rear sump oil pan and sump to give axle clearance. and a modified tranny crossmember to support the tranny mount. I really question the builder's competency if this install is a stumbling block, it's about as basic a swap as there is. Mid Fifty offers a cut to fit tubular motor mount for the 289 that should work with the F-1 frame.
__________________
Passionate about autocross racing!
1956 F100 Panel "GRACIE"
2007 Solstice GXP racer, the "KRAZED KANARY"
Third place finish 2009 SCCA National Championships
Old 07-26-2013, 12:53 PM
Dobies4life's Avatar
Dobies4life Dobies4life is offline
Dobies4life is starting off with a positive reputation.
Wouldnt a mustang t5 put the shifter between a pair of buckets? Or up through the bench seat? the shifter on the mustang versions is at the rear of the housing correct?
__________________
49 F1-351c-ZFs542-9inch
65 Comet Caliente(2 dr hard top)-302-t10-9inch
Old 07-26-2013, 12:57 PM
AXracer's Avatar
Chuck Frank
That is quite possible with a bench seat. Can use the tail shaft and housing from an S10 to move the shifter forwards.
__________________
Old 07-26-2013, 01:33 PM
tacson's Avatar
Quote:
Yeah it does and that was one of the things he was asking me and I wasn't sure of an alternative
Quote:
real good to know AX I will share the info.
Quote:
Originally Posted by Phity Five View Post
I used something like these...
700R4 4L60E T56 T5 Universal Transmission Crossmember 3" Drop | eBay
1994 1998 Ford Mustang Transmission Mount T5 Manual | eBay
They can be found pretty easily on the interweb.
Cheers Brian
Thanks Brian
My friend is a guy I struck up a friendship with a cruise in and we talked the other night. His "builder" leaves a lot to question and I will say no more. If anybody has any additional info please share. I trying to keep my friend from taking the leap and selling his father/son project. Thanks again every one
__________________
DONALD
Old 07-26-2013, 01:50 PM
52 Merc's Avatar
52 Merc 52 Merc is offline
52 Merc is a splendid one to behold52 Merc is a splendid one to behold52 Merc is a splendid one to behold52 Merc is a splendid one to behold52 Merc is a splendid one to behold52 Merc is a splendid one to behold
I installed a 66 289 and a C4 trans in a '50 back in the 70's when I was a kid. So I know the SBF will fit in place perfectly without any cutting or modifying the frame or floor/firewall, and using the stock front sump oil pan. We made our own side mounts and welded them to the frame, no aftermarket crossmember necessary.
The mount on the C4 lines up perfectly with the original crossmember and all that needs to happen there is to create a pad for the insulator to attach. The T5 is a different issue. The trans itself is larger and longer, so one must get considerably more creative to install the gearbox over the slushbox. There is a thread in here somewhere that showed one guy's custom install where he created a gorgeous extension to the crossmember from scratch to make everything fit like it should. It's definitely some work, but totally do-able.
__________________
Wayne
52 Mercury M-1
among other things.
Old 07-26-2013, 01:57 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is offline
postin' fool
ALBUQ F-1 has much to be proud ofALBUQ F-1 has much to be proud ofALBUQ F-1 has much to be proud ofALBUQ F-1 has much to be proud ofALBUQ F-1 has much to be proud ofALBUQ F-1 has much to be proud ofALBUQ F-1 has much to be proud ofALBUQ F-1 has much to be proud ofALBUQ F-1 has much to be proud of
For a mild 289, he can use a later-model S-10 T5 ('91-on, I think), as they are world class, have the Ford bolt patteren on the trans, and have the desirable shifter. Only thing is, they also have the 4.03 1st gear. Adapting the input shaft may be more trouble than it's worth, too. There are kits everywhere to put a T5 behind a flathead, and I see the stock engine mounts are still there..... Hmmmmm....
__________________
Ross
1952 F-1 Flat V8 3-on-the-tree MSD, Rochester 2G, Red's Headers
Old 07-26-2013, 07:37 PM
AXracer's Avatar
Chuck Frank
The shifter location is the biggest stumbling block. Easiest solution is a set of bucket seats. The tailshaft swap is a simple bolt in, just be sure to use a world class tailshaft assembly with a world class T5 tranny, or a non world class tailshaft assembly with a non world class T5. (do a search on the web to learn the differences and instructions on swapping the tailshafts). It's not a difficult process and within the capabilities of anyone with average mechanical skills and tools.
__________________
Similar Threads
Had some fun tonight bobj49f2 1948 - 1956 F1, F100 & Larger F-Series Trucks 27 06-13-2013 09:51 PM
Photos modifications 2004 Excursion V10 4x4 Xv10 Excursion - King of SUVs 38 05-01-2012 06:04 PM
New Member, 'New' F1 Grandpa-50 1948 - 1956 F1, F100 & Larger F-Series Trucks 26 10-10-2011 02:44 AM
progress update on the bed make over. 65fordguy 1961 - 1966 F-100 & Larger F-Series Trucks 10 11-12-2009 01:26 AM
mother nature 1 us 0 460429_freak Missouri Chapter 3 05-14-2009 02:56 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
